Disable SIP Options
Hi
Is it possible to disable the SIP options ping?
I have a 2 trunks and one of them doesnt require SIP options so ideally id like to disable it on that trunk if possible?
If not is it possible to disable fully on the PBX?
I found the below for asterisk but it doesnt appear to be in the sip.conf file:
set qualify=no in sip.conf and it will stop. qualify= means it uses sip options to ‘ping’
Thanks,
Rob
Are you using SIP or PJSIP trunks?
PJSIP Trunks
:grinning: :smiley: :smile: :grin: :laughing:
In your trunk, set the parameter “Qualify Frequency” to Zero(0).
Perfect, thank you :slight_smile:
