Where has the disable ICMP Option been moved to in version 4.5 ?
It used to be in the firewall page but is now gone.
Any idea how I can disable IMCP
Looks like it is missing from 4.2 as well.
I moved this topic to Reporting an Issue and hopefully, it’ll be fixed.
In the meantime, you can block it directly within IP Tables.
That’s something with remove because some customers experiencing issues with the Asterisk Options when the IMCP got disabled!
