Disable https via command lineon VitalPBX
How can you disable the connection to vitalpbx via https and use http again, in case you do not have access to GIU management through the application’s web server.
You can access the list of available vitalpbx commands using vitalpbx help
Now, you can execute the commands below depending on your O.S version for your specific case.
VitalPBX 4.5 (Debian 12)
vitalpbx reset-web-server
VitalPBX 4 (Debian 11)
vitalpbx reset-apache-conf
Thansk a lot for the quick answer Miguel
LFM
