When saving and reloading, I cannot get a “+1” to save in the Twilio Trunk Dialing Manipulation rules. Is there something that would block this from saving? Call from my trunk are going to Twilio without the +1 at the beginning and it fails the call. I need them to go out as “sip:+15555555555@155.XXX.XXX.101” instead of “sip:5555555555@155.XXX.XXX.101”.
Here are a couple of options:
- Add the prefix in the outbound routes.
- Add the prefix in the prefix field of the trunk.
Now, if you want to use the Dialing manipulation rules, then you have to define a pattern in order to save the settings.
