Device creation limitation
I wish to add a device creation limitation in the Tenant to avoid creating more devices for the Extensions.
Momen Amin
You can limit the number of extensions per tenant. That’s a setting that you can edit/configure when creating/editing a tenant!
Unfortunately, that’s not restrict/limit the Tenant to create more devices!
So, that’s not a solution!
Even if the user creates multiple devices, they will be attached to the same extension. That’s why they are not limited.
The problem is that many of us are charging “per connection” so, if they can connect multiple devices, the tenant can connect unlimited devices…
Even limiting devices, the users will be able to define up to 100 Contacts per device. So, you can connect 100 Phone Devices to a single PJSIP Account!
Indeed. So we would love to be able to limit the amount of devices as well as the amount of max contacts per device.
