is it possible to have a custom sip Headers in a tenant trunk
onder the tap advanced
Can anyone please help
Yes, that is exactly what the section is for. As an example I use the X-Tenant header on the outbound trunks to define which tenant is making the calls so that my trunk provider can properly track usage.
It does not seem like it is possible at the moment. You can request this feature under #wish-list
Anyway, you can set the headers on the parent Trunk using a variable set on the tenant level.
