Custom In Call Feature Code
How to implement on Vitalpbx Custom Feature Code in call wich allow user to dail DTMF on call to excute dial plan
Appreciate the help
Create a Custom Application that points to a Custom Context.
Edit: Are you referring to a mid call?
If so, VitalPBX allows you to utilize the CUSTOM_DYNAMIC_FEATURES variable to set custom Dynamic Featues.
You would need to set that variable at the beginning of your call as a Global Variable.
