You can only find it using sarch. Supose do be bellow TOOLS
Goto PBX > Tools Where it says it is in what you circled.
Nope, bellow tools on left menu dont show Tasks or Cron Profiles. Only way to access this modules is using search tools. I believe its a bug
You are in the wrong section, you need to be in the tools under PBX. You are looking under ADMIN and that’s not where it says to look.
