CRM integration
I am looking for a development .
Create an integration between vitalPbx (multi-tenant) and the CRM system (json)
in Paid.
You can use webhook with your CRM using VitXi interface
But that’s not what I’m looking for
Please describe the way of integration you want
We basically need to be called whenever there’s a RINGING, ANSWER or HANGUP event at an extension.
This is the format if the JSON we need to get in case of an incoming call, for each event
UUID: Unique ID of the call, must be the same in all 3 statuses of the call (RINGING, ANSWER, HANGUP)
