Connect an external Drive in VitalPBX4 HA
Continuing the discussion from How to connect an external drive (NAS or Storage Server) in VitalPBX to store the recordings?:
I have no problem mounting the shared directory in which the audio are going to be recorded. I’m able to create file or directories.
When running this commands, everything seems to ve fine.:
cd /var/spool/asterisk/
ln -s /nfs/recordings/ monitor
chown -R asterisk:asterisk monitor
The symbolic link was create inside /var/spool/asterisk/monitor/ and the audios files keep being save on /var/spool/asterisk/monitor
Remove the symbolic link
rmdir monitor
So far, is was looking ok, but when I made a test call the audio did not get recorded (both extension had enable recording incoming/outgoing/internal)
I check the full log for that call , and it shows the directory in which the audio is going to be saved, no error
[2023-05-17 08:40:44] WARNING[80242][C-00000001] file.c: Unable to open file /var/spool/asterisk/monitor/2023/05/17/084036-LOCAL-Q10-101-102-1684334436.0.wav: Permission denied
[2023-05-17 08:40:44] ERROR[80242][C-00000001] app_mixmonitor.c: Cannot open /var/spool/asterisk/monitor/2023/05/17/084036-LOCAL-Q10-101-102-1684334436.0.wav
Asterisk needs to be able to write to the folder, otherwise you get the permission errors you are getting.
chown asterisk:asterisk /var/spool/asterisk/monitor
chown asterisk:asterisk /mnt/monitor
