Configure inbound and outbound routes in multi tenant
Hello
I have multi-tenants, and I want to configure routes for the incoming and outgoing calls, and I have a service provider
Should the trunk be configured for the service provider for each tenant, or in a main tenant? note that all tenants will be using it as inbound and outbound.
How can I assign the DID for each tenant, and should create an inbound route for each tenant? or in the main tenant
if anybody has the same scenario please share the steps
Normally you’d create a single trunk on the main tenant and then map DIDs under each tenant.
