apache2/ports.conf:
Listen 4444
apache2/sites-available/default-ssl.conf:
VirtualHost default:4444
apache2/sites-available/vitalpbx.conf:
VirtualHost *:4444
Also updated from GUI FW Service. GUI is working.
But when i try to save something, i got an error:
An exception has occurred
Exception: API Error: [POST] /events 0 - Failed to connect to 127.0.0.1 port 443: Connection refused at file /usr/share/vitalpbx/www/includes/rest_client.php on line 0
Error Trace
# File Function
1 /usr/share/vitalpbx/www/index.php:0 app\Core->run(...args);
2 /usr/share/vitalpbx/www/includes/app/Core.php:0 app\Core->_loadModule(...args);
3 /usr/share/vitalpbx/www/includes/app/Core.php:0 app\Core->loadModuleAction(...args);
4 /usr/share/vitalpbx/www/includes/app/Core.php:0 modules\extensions\extensions->put(...args);
5 /usr/share/vitalpbx/www/modules/extensions/extensions.php:0 modules\extensions\DBStorage->put(...args);
6 /usr/share/vitalpbx/www/modules/extensions/DBStorage.php:0 modules\extensions\DBStorage->save(...args);
7 /usr/share/vitalpbx/www/modules/extensions/DBStorage.php:0 modules\extensions\DBStorage->putExtension(...args);
8 /usr/share/vitalpbx/www/modules/extensions/DBStorage.php:0 EventLogger\EventLogger->addRecord(...args);
9 /usr/share/vitalpbx/www/includes/components/EventLogger/EventLogger.php:0 EventLogger\EventLogger->_addEvent(...args);
10 /usr/share/vitalpbx/www/includes/components/EventLogger/EventLogger.php:0 vitalpbx\rest_client->post(...args);
11 /usr/share/vitalpbx/www/includes/rest_client.php:0 vitalpbx\rest_client->execute(...args);
It was working perfectly before last update (today).
Is working perfectly when I go back to use 443.
It is not working when i manage to change to 4444. It is still trying to use 443 for some actions.
