can not GUI logout (vitalpbx 4.1.0-1)
After update
here is screen
Are you using a valid SSL?
Execute the script below.
/usr/share/vitalpbx/scripts/apache_conf
Then, restart Apache
systemctl restart apache2
i tried but it was same.
It beats me!
I have done test over HTTP and HTTPs and all is working flawlessly!
here is my step
vitalpbx 4.0.7.R3
a. GUI login and update. but it could not update.
b. try manual migrations *.sql files
c. vitalpbx update. SUCESS
d. vitalpbx (4.1.0.-1) GUI ERROR.
e. /usr/share/vitalpbx/scripts/apache_conf and systemctl restart apache2
f. same
thanks
new install is perfect works!
It not works, when only update issue.
It beats me too!
i fix it
it was my fault
don’t database(*.sql) migration manually.
thanks for help.
