Can not add-ons check online
this is emergency
i got new install by vps.sh on centos 7.9
after gui access is ok
but i could not add-ons and gui updates.
like this
스크린샷 2022-10-20 오후 2.31.49
Your installation may be corrupted in some way!
Did you install the server in a public VPS like Digital Ocean, Google Cloud, etc.?
i installed on onpremise.
here is my install step.
  1. install centos 7.x minimal
  2. download scripts vps.sh
  3. install by vps.sh
  4. and web login
Just did a clean install of Cent OS and vps.sh on Vultr.
Went to Add-ons. Clicked “check online”, installed custom context and dynamic destinations and everything went smooth.
“Check for updates” was fine as well.
how to check my vpbx server.
i already checked
check-integrity
reset-apache-conf
build-db
thanks
Did it help? You did not say that.
i already checked but nothing to help
please let me know other options ?
thanks
  • Is your VM behind a proxy/network filter?
  • Make sure you have proper DNS
  • Do a traceroute to see where it gets blocked
  • Maybe even a tcpdump
What PitzKey says.
And try this as well:
i will try.
but yum installed and remove working possble that means dns is OK.
it is not VM. i installed onpremise on CentOS 7.X
thanks PitzKey.
I tried this post.
but same problem. again.
i think somthing miss install while i installed first time.
thanks mo10.
Then just run the VPs.sh again.
And do another VM and try again.
mo10,
Okay.
thanks for your help.
thanks mo10,
could you try install with korea IP.
i tried a lot of different sites. but same in korea.
