Here is a snippet of the asterisk log
[2022-03-01 10:08:55] VERBOSE[2119] chan_iax2.c: Accepting AUTHENTICATED call from 172.16.1.135:4569:
> requested format = ulaw,
> requested prefs = (ulaw|alaw|gsm),
> actual format = ulaw,
> host prefs = (ulaw|alaw|g729),
> priority = caller
[2022-03-01 10:08:55] VERBOSE[31432][C-00000144] pbx.c: Executing [360785XXXX@trk-4-in:1] NoOp(“IAX2/pittpbxiax-15662”, “Incoming call through: Pittpbxiax”) in new stack
[2022-03-01 10:08:55] VERBOSE[31432][C-00000144] pbx.c: Executing [360785XXXX@trk-4-in:2] Set(“IAX2/pittpbxiax-15662”, “__TRUNK_ID=4”) in new stack
[2022-03-01 10:08:55] VERBOSE[31432][C-00000144] pbx.c: Executing [360785XXXX@trk-4-in:3] Set(“IAX2/pittpbxiax-15662”, “CDR(trunk)=4”) in new stack
[2022-03-01 10:08:55] VERBOSE[31432][C-00000144] pbx.c: Executing [360785XXXX@trk-4-in:4] Set(“IAX2/pittpbxiax-15662”, “__DID_NUMBER=360785XXXX”) in new stack
[2022-03-01 10:08:55] VERBOSE[31432][C-00000144] pbx.c: Executing [360785XXXX@trk-4-in:5] Set(“IAX2/pittpbxiax-15662”, “CDR(did)=360785XXXX”) in new stack
[2022-03-01 10:08:55] VERBOSE[31432][C-00000144] pbx.c: Executing [360785XXXX@trk-4-in:6] Set(“IAX2/pittpbxiax-15662”, “DID=360785XXXX”) in new stack
[2022-03-01 10:08:55] VERBOSE[31432][C-00000144] pbx.c: Executing [360785XXXX@trk-4-in:7] Goto(“IAX2/pittpbxiax-15662”, “cos-all-trunk,360785XXXX,1”) in new stack
[2022-03-01 10:08:55] VERBOSE[31432][C-00000144] pbx_builtins.c: Goto (cos-all-trunk,360785XXXX,1)
[2022-03-01 10:08:55] VERBOSE[31432][C-00000144] pbx.c: Executing [360785XXXX@cos-all-trunk:1] NoOp(“IAX2/pittpbxiax-15662”, “Class of Services Trunk: All Permissions”) in new stack
[2022-03-01 10:08:55] VERBOSE[31432][C-00000144] pbx.c: Executing [360785XXXX@cos-all-trunk:2] Gosub(“IAX2/pittpbxiax-15662”, “sub-check-blacklist,s,1(27f1dbdefd9de0f4,+1620687XXXX)”) in new stack
[2022-03-01 10:08:55] VERBOSE[31432][C-00000144] pbx.c: Executing [s@sub-check-blacklist:1] NoOp(“IAX2/pittpbxiax-15662”, “Testing if +1620687XXXX is in Black List”) in new stack
[2022-03-01 10:08:55] VERBOSE[31432][C-00000144] pbx.c: Executing [s@sub-check-blacklist:2] GotoIf(“IAX2/pittpbxiax-15662”, “0?banned”) in new stack
[2022-03-01 10:08:55] VERBOSE[31432][C-00000144] pbx.c: Executing [s@sub-check-blacklist:3] Return(“IAX2/pittpbxiax-15662”, “”) in new stack
[2022-03-01 10:08:55] VERBOSE[31432][C-00000144] pbx.c: Executing [360785XXXX@cos-all-trunk:3] Gosub(“IAX2/pittpbxiax-15662”, “sub-setup-call-type,s,1(incoming)”) in new stack
[2022-03-01 10:08:55] VERBOSE[31432][C-00000144] pbx.c: Executing [s@sub-setup-call-type:1] NoOp(“IAX2/pittpbxiax-15662”, “Determinating Call Type”) in new stack
[2022-03-01 10:08:55] VERBOSE[31432][C-00000144] pbx.c: Executing [s@sub-setup-call-type:2] GotoIf(“IAX2/pittpbxiax-15662”, “0?return”) in new stack
[2022-03-01 10:08:55] VERBOSE[31432][C-00000144] pbx.c: Executing [s@sub-setup-call-type:3] Gosub(“IAX2/pittpbxiax-15662”, “s-incoming,1()”) in new stack
[2022-03-01 10:08:55] VERBOSE[31432][C-00000144] pbx.c: Executing [s-incoming@sub-setup-call-type:1] NoOp(“IAX2/pittpbxiax-15662”, “Incoming Call”) in new stack
[2022-03-01 10:08:55] VERBOSE[31432][C-00000144] pbx.c: Executing [s-incoming@sub-setup-call-type:2] Set(“IAX2/pittpbxiax-15662”, “__CALL_TYPE=2”) in new stack
[2022-03-01 10:08:55] VERBOSE[31432][C-00000144] pbx.c: Executing [s-incoming@sub-setup-call-type:3] Set(“IAX2/pittpbxiax-15662”, “__CALL_TYPE_LABEL=IN”) in new stack
[2022-03-01 10:08:55] VERBOSE[31432][C-00000144] pbx.c: Executing [s-incoming@sub-setup-call-type:4] Return(“IAX2/pittpbxiax-15662”, “”) in new stack
[2022-03-01 10:08:55] VERBOSE[31432][C-00000144] pbx.c: Executing [s@sub-setup-call-type:4] Set(“IAX2/pittpbxiax-15662”, “__CALL_TYPE_CONFIGURED=yes”) in new stack
[2022-03-01 10:08:55] VERBOSE[31432][C-00000144] pbx.c: Executing [s@sub-setup-call-type:5] Set(“IAX2/pittpbxiax-15662”, “CDR(calltype)=2”) in new stack
[2022-03-01 10:08:55] VERBOSE[31432][C-00000144] pbx.c: Executing [s@sub-setup-call-type:6] Return(“IAX2/pittpbxiax-15662”, “”) in new stack
[2022-03-01 10:08:55] VERBOSE[31432][C-00000144] pbx.c: Executing [360785XXXX@cos-all-trunk:4] Gosub(“IAX2/pittpbxiax-15662”, “sub-set-call-vars,s-incoming,1(+1620687XXXX,360785XXXX,27f1dbdefd9de0f4)”) in new stack
[2022-03-01 10:08:55] VERBOSE[31432][C-00000144] pbx.c: Executing [s-incoming@sub-set-call-vars:1] NoOp(“IAX2/pittpbxiax-15662”, “Setting Incoming Call Vars”) in new stack
[2022-03-01 10:08:55] VERBOSE[31432][C-00000144] pbx.c: Executing [s-incoming@sub-set-call-vars:2] Set(“IAX2/pittpbxiax-15662”, “__CALLID=1646150935.3658”) in new stack
[2022-03-01 10:08:55] VERBOSE[31432][C-00000144] pbx.c: Executing [s-incoming@sub-set-call-vars:3] Set(“IAX2/pittpbxiax-15662”, “__INCOMING_SOURCE=+1620687XXXX”) in new stack
[2022-03-01 10:08:55] VERBOSE[31432][C-00000144] pbx.c: Executing [s-incoming@sub-set-call-vars:4] Set(“IAX2/pittpbxiax-15662”, “__INCOMING_DESTINATION=360785XXXX”) in new stack
[2022-03-01 10:08:55] VERBOSE[31432][C-00000144] pbx.c: Executing [s-incoming@sub-set-call-vars:5] Set(“IAX2/pittpbxiax-15662”, “__INCOMING_TENANT=27f1dbdefd9de0f4”) in new stack
[2022-03-01 10:08:55] VERBOSE[31432][C-00000144] pbx.c: Executing [s-incoming@sub-set-call-vars:6] Set(“IAX2/pittpbxiax-15662”, “__CALL_SOURCE=+1620687XXXX”) in new stack
[2022-03-01 10:08:55] VERBOSE[31432][C-00000144] pbx.c: Executing [s-incoming@sub-set-call-vars:7] Set(“IAX2/pittpbxiax-15662”, “__CS=+1620687XXXX”) in new stack
[2022-03-01 10:08:55] VERBOSE[31432][C-00000144] pbx.c: Executing [s-incoming@sub-set-call-vars:8] Set(“IAX2/pittpbxiax-15662”, “__CALL_DESTINATION=360785XXXX”) in new stack
[2022-03-01 10:08:55] VERBOSE[31432][C-00000144] pbx.c: Executing [s-incoming@sub-set-call-vars:9] Set(“IAX2/pittpbxiax-15662”, “__TENANT=27f1dbdefd9de0f4”) in new stack
[2022-03-01 10:08:55] VERBOSE[31432][C-00000144] pbx.c: Executing [s-incoming@sub-set-call-vars:10] Set(“IAX2/pittpbxiax-15662”, “CDR(tenant)=vitalpbx”) in new stack
[2022-03-01 10:08:55] VERBOSE[31432][C-00000144] pbx.c: Executing [s-incoming@sub-set-call-vars:11] Set(“IAX2/pittpbxiax-15662”, “CDR(destination)=360785XXXX”) in new stack
[2022-03-01 10:08:55] VERBOSE[31432][C-00000144] pbx.c: Executing [s-incoming@sub-set-call-vars:12] Set(“IAX2/pittpbxiax-15662”, “CDR(trunk)=4”) in new stack
[2022-03-01 10:08:55] VERBOSE[31432][C-00000144] pbx.c: Executing [s-incoming@sub-set-call-vars:13] Set(“IAX2/pittpbxiax-15662”, “CDR(did)=360785XXXX”) in new stack
[2022-03-01 10:08:55] VERBOSE[31432][C-00000144] pbx.c: Executing [s-incoming@sub-set-call-vars:14] Set(“IAX2/pittpbxiax-15662”, “CDR(calltype)=2”) in new stack
[2022-03-01 10:08:55] VERBOSE[31432][C-00000144] pbx.c: Executing [s-incoming@sub-set-call-vars:15] Gosub(“IAX2/pittpbxiax-15662”, “app-incoming,1”) in new stack
[2022-03-01 10:08:55] VERBOSE[31432][C-00000144] pbx.c: Executing [app-incoming@sub-set-call-vars:1] NoOp(“IAX2/pittpbxiax-15662”, “Incoming Call App CDR”) in new stack
[2022-03-01 10:08:55] VERBOSE[31432][C-00000144] pbx.c: Executing [app-incoming@sub-set-call-vars:2] GotoIf(“IAX2/pittpbxiax-15662”, “1?:return”) in new stack
[2022-03-01 10:08:55] VERBOSE[31432][C-00000144] pbx.c: Executing [app-incoming@sub-set-call-vars:3] Set(“IAX2/pittpbxiax-15662”, “CDR(source)=+1620687XXXX”) in new stack
[2022-03-01 10:08:55] VERBOSE[31432][C-00000144] pbx.c: Executing [app-incoming@sub-set-call-vars:4] Set(“IAX2/pittpbxiax-15662”, “CDR(tenant)=vitalpbx”) in new stack
[2022-03-01 10:08:55] VERBOSE[31432][C-00000144] pbx.c: Executing [app-incoming@sub-set-call-vars:5] Set(“IAX2/pittpbxiax-15662”, “CDR(destination)=360785XXXX”) in new stack
[2022-03-01 10:08:55] VERBOSE[31432][C-00000144] pbx.c: Executing [app-incoming@sub-set-call-vars:6] Return(“IAX2/pittpbxiax-15662”, “”) in new stack
[2022-03-01 10:08:55] VERBOSE[31432][C-00000144] pbx.c: Executing [s-incoming@sub-set-call-vars:16] Return(“IAX2/pittpbxiax-15662”, “”) in new stack
[2022-03-01 10:08:55] VERBOSE[31432][C-00000144] pbx.c: Executing [360785XXXX@cos-all-trunk:5] Goto(“IAX2/pittpbxiax-15662”, “cos-all,360785XXXX,1”) in new stack
[2022-03-01 10:08:55] VERBOSE[31432][C-00000144] pbx_builtins.c: Goto (cos-all,360785XXXX,1)
[2022-03-01 10:08:55] VERBOSE[31432][C-00000144] pbx.c: Executing [360785XXXX@cos-all:1] NoOp(“IAX2/pittpbxiax-15662”, “More than on digit pattern”) in new stack
[2022-03-01 10:08:55] VERBOSE[31432][C-00000144] pbx.c: Executing [360785XXXX@cos-all:2] Gosub(“IAX2/pittpbxiax-15662”, “s,1(360785XXXX)”) in new stack
[2022-03-01 10:08:55] VERBOSE[31432][C-00000144] pbx.c: Executing [s@cos-all:1] Set(“IAX2/pittpbxiax-15662”, “EXTENSION=360785XXXX”) in new stack
[2022-03-01 10:08:55] VERBOSE[31432][C-00000144] pbx.c: Executing [s@cos-all:2] NoOp(“IAX2/pittpbxiax-15662”, “Dialing 360785XXXX from +1620687XXXX”) in new stack
[2022-03-01 10:08:55] VERBOSE[31432][C-00000144] pbx.c: Executing [s@cos-all:3] Gosub(“IAX2/pittpbxiax-15662”, “sub-set-global-vars,s,1(27f1dbdefd9de0f4,360785XXXX,parking-1)”) in new stack
[2022-03-01 10:08:55] VERBOSE[31432][C-00000144] pbx.c: Executing [s@sub-set-global-vars:1] NoOp(“IAX2/pittpbxiax-15662”, “Setting Global Vars”) in new stack
[2022-03-01 10:08:55] VERBOSE[31432][C-00000144] pbx.c: Executing [s@sub-set-global-vars:2] Set(“IAX2/pittpbxiax-15662”, “TENANT_PATH=27f1dbdefd9de0f4”) in new stack
[2022-03-01 10:08:55] VERBOSE[31432][C-00000144] pbx.c: Executing [s@sub-set-global-vars:3] Set(“IAX2/pittpbxiax-15662”, “PREFIX=”) in new stack
[2022-03-01 10:08:55] VERBOSE[31432][C-00000144] pbx.c: Executing [s@sub-set-global-vars:4] Set(“IAX2/pittpbxiax-15662”, “__PICKUPMARK=360785XXXX”) in new stack
[2022-03-01 10:08:55] VERBOSE[31432][C-00000144] pbx.c: Executing [s@sub-set-global-vars:5] Set(“IAX2/pittpbxiax-15662”, “__PARKINGLOT=parking-1”) in new stack
[2022-03-01 10:08:55] VERBOSE[31432][C-00000144] pbx.c: Executing [s@sub-set-global-vars:6] Set(“IAX2/pittpbxiax-15662”, “__DYNAMIC_FEATURES=custom-features”) in new stack
[2022-03-01 10:08:55] VERBOSE[31432][C-00000144] pbx.c: Executing [s@sub-set-global-vars:7] Set(“IAX2/pittpbxiax-15662”, “ICALL=no”) in new stack
[2022-03-01 10:08:55] VERBOSE[31432][C-00000144] pbx.c: Executing [s@sub-set-global-vars:8] Return(“IAX2/pittpbxiax-15662”, “”) in new stack
[2022-03-01 10:08:55] VERBOSE[31432][C-00000144] pbx.c: Executing [s@cos-all:4] Gosub(“IAX2/pittpbxiax-15662”, “sub-set-call-vars,s,1(27f1dbdefd9de0f4,360785XXXX,1,cos-all,ARS-all)”) in new stack
[2022-03-01 10:08:55] VERBOSE[31432][C-00000144] pbx.c: Executing [s@sub-set-call-vars:1] NoOp(“IAX2/pittpbxiax-15662”, “Setting Call Vars”) in new stack
[2022-03-01 10:08:55] VERBOSE[31432][C-00000144] pbx.c: Executing [s@sub-set-call-vars:2] Set(“IAX2/pittpbxiax-15662”, “_TENANT=27f1dbdefd9de0f4”) in new stack
[2022-03-01 10:08:55] VERBOSE[31432][C-00000144] pbx.c: Executing [s@sub-set-call-vars:3] Set(“IAX2/pittpbxiax-15662”, “_CALL_DESTINATION=360785XXXX”) in new stack
[2022-03-01 10:08:55] VERBOSE[31432][C-00000144] pbx.c: Executing [s@sub-set-call-vars:4] Set(“IAX2/pittpbxiax-15662”, “_COS_ID=1”) in new stack
[2022-03-01 10:08:55] VERBOSE[31432][C-00000144] pbx.c: Executing [s@sub-set-call-vars:5] Set(“IAX2/pittpbxiax-15662”, “_COS_NAME=cos-all”) in new stack
[2022-03-01 10:08:55] VERBOSE[31432][C-00000144] pbx.c: Executing [s@sub-set-call-vars:6] Set(“IAX2/pittpbxiax-15662”, “__TRANSFER_CONTEXT=cos-all”) in new stack
[2022-03-01 10:08:55] VERBOSE[31432][C-00000144] pbx.c: Executing [s@sub-set-call-vars:7] Set(“IAX2/pittpbxiax-15662”, “_ARS=ARS-all”) in new stack
[2022-03-01 10:08:55] VERBOSE[31432][C-00000144] pbx.c: Executing [s@sub-set-call-vars:8] Set(“IAX2/pittpbxiax-15662”, “CDR(tenant)=vitalpbx”) in new stack
[2022-03-01 10:08:55] VERBOSE[31432][C-00000144] pbx.c: Executing [s@sub-set-call-vars:9] Set(“IAX2/pittpbxiax-15662”, “CDR(destination)=360785XXXX”) in new stack
[2022-03-01 10:08:55] VERBOSE[31432][C-00000144] pbx.c: Executing [s@sub-set-call-vars:10] Set(“IAX2/pittpbxiax-15662”, “CDR(trunk)=4”) in new stack
[2022-03-01 10:08:55] VERBOSE[31432][C-00000144] pbx.c: Executing [s@sub-set-call-vars:11] Set(“IAX2/pittpbxiax-15662”, “CDR(did)=360785XXXX”) in new stack
[2022-03-01 10:08:55] VERBOSE[31432][C-00000144] pbx.c: Executing [s@sub-set-call-vars:12] Set(“IAX2/pittpbxiax-15662”, “__CALLID=1646150935.3658”) in new stack
[2022-03-01 10:08:55] VERBOSE[31432][C-00000144] pbx.c: Executing [s@sub-set-call-vars:13] ExecIf(“IAX2/pittpbxiax-15662”, “0?Set(CHANNEL(language)=)”) in new stack
[2022-03-01 10:08:55] VERBOSE[31432][C-00000144] pbx.c: Executing [s@sub-set-call-vars:14] ExecIf(“IAX2/pittpbxiax-15662”, “0?Set(CHANNEL(language)=)”) in new stack
[2022-03-01 10:08:55] VERBOSE[31432][C-00000144] pbx.c: Executing [s@sub-set-call-vars:15] Return(“IAX2/pittpbxiax-15662”, “”) in new stack
[2022-03-01 10:08:55] VERBOSE[31432][C-00000144] pbx.c: Executing [s@cos-all:5] Gosub(“IAX2/pittpbxiax-15662”, “sub-construct-cid,s,1”) in new stack
[2022-03-01 10:08:55] VERBOSE[31432][C-00000144] pbx.c: Executing [s@sub-construct-cid:1] NoOp(“IAX2/pittpbxiax-15662”, “Building CID”) in new stack
[2022-03-01 10:08:55] VERBOSE[31432][C-00000144] pbx.c: Executing [s@sub-construct-cid:2] Set(“IAX2/pittpbxiax-15662”, “_CALL_SOURCE=+1620687XXXX”) in new stack
[2022-03-01 10:08:55] VERBOSE[31432][C-00000144] pbx.c: Executing [s@sub-construct-cid:3] Set(“IAX2/pittpbxiax-15662”, “_CS=+1620687XXXX”) in new stack
[2022-03-01 10:08:55] VERBOSE[31432][C-00000144] pbx.c: Executing [s@sub-construct-cid:4] GotoIf(“IAX2/pittpbxiax-15662”, “0?return”) in new stack
[2022-03-01 10:08:55] VERBOSE[31432][C-00000144] pbx.c: Executing [s@sub-construct-cid:5] Gosub(“IAX2/pittpbxiax-15662”, “sub-get-device-tree,s,1”) in new stack
[2022-03-01 10:08:55] VERBOSE[31432][C-00000144] pbx.c: Executing [s@sub-get-device-tree:1] NoOp(“IAX2/pittpbxiax-15662”, “Configuring Device Tree”) in new stack
[2022-03-01 10:08:55] VERBOSE[31432][C-00000144] pbx.c: Executing [s@sub-get-device-tree:2] Set(“IAX2/pittpbxiax-15662”, “DEV_TECHNOLOGY=IAX2”) in new stack
[2022-03-01 10:08:55] VERBOSE[31432][C-00000144] pbx.c: Executing [s@sub-get-device-tree:3] GosubIf(“IAX2/pittpbxiax-15662”, “0?s-local,1”) in new stack
[2022-03-01 10:08:55] VERBOSE[31432][C-00000144] pbx.c: Executing [s@sub-get-device-tree:4] GotoIf(“IAX2/pittpbxiax-15662”, “0?return”) in new stack
[2022-03-01 10:08:55] VERBOSE[31432][C-00000144] pbx.c: Executing [s@sub-get-device-tree:5] GotoIf(“IAX2/pittpbxiax-15662”, “0?pjsip”) in new stack
[2022-03-01 10:08:55] VERBOSE[31432][C-00000144] pbx.c: Executing [s@sub-get-device-tree:6] GotoIf(“IAX2/pittpbxiax-15662”, “0?:digital”) in new stack
[2022-03-01 10:08:55] VERBOSE[31432][C-00000144] pbx_builtins.c: Goto (sub-get-device-tree,s,12)
[2022-03-01 10:08:55] VERBOSE[31432][C-00000144] pbx.c: Executing [s@sub-get-device-tree:12] Set(“IAX2/pittpbxiax-15662”, “DEV_USER=pittpbxiax”) in new stack
[2022-03-01 10:08:55] VERBOSE[31432][C-00000144] pbx.c: Executing [s@sub-get-device-tree:13] Set(“IAX2/pittpbxiax-15662”, “_INTERFACE=IAX2/pittpbxiax”) in new stack
[2022-03-01 10:08:55] VERBOSE[31432][C-00000144] pbx.c: Executing [s@sub-get-device-tree:14] Set(“IAX2/pittpbxiax-15662”, “DEV_TREE=devices/IAX2/pittpbxiax”) in new stack
[2022-03-01 10:08:55] VERBOSE[31432][C-00000144] pbx.c: Executing [s@sub-get-device-tree:15] Return(“IAX2/pittpbxiax-15662”, “”) in new stack
[2022-03-01 10:08:55] VERBOSE[31432][C-00000144] pbx.c: Executing [s@sub-construct-cid:6] GotoIf(“IAX2/pittpbxiax-15662”, “0?return”) in new stack
[2022-03-01 10:08:55] VERBOSE[31432][C-00000144] pbx.c: Executing [s@sub-construct-cid:7] Set(“IAX2/pittpbxiax-15662”, “_CALL_SOURCE=+1620687XXXX”) in new stack
[2022-03-01 10:08:55] VERBOSE[31432][C-00000144] pbx.c: Executing [s@sub-construct-cid:8] Set(“IAX2/pittpbxiax-15662”, “_CS=+1620687XXXX”) in new stack
[2022-03-01 10:08:55] VERBOSE[31432][C-00000144] pbx.c: Executing [s@sub-construct-cid:9] ExecIf(“IAX2/pittpbxiax-15662”, “0?Set(CALLERID(all)=)”) in new stack
[2022-03-01 10:08:55] VERBOSE[31432][C-00000144] pbx.c: Executing [s@sub-construct-cid:10] Set(“IAX2/pittpbxiax-15662”, “_CID_CONSTRUCTED=yes”) in new stack
[2022-03-01 10:08:55] VERBOSE[31432][C-00000144] pbx.c: Executing [s@sub-construct-cid:11] NoOp(“IAX2/pittpbxiax-15662”, “”) in new stack
[2022-03-01 10:08:55] VERBOSE[31432][C-00000144] pbx.c: Executing [s@sub-construct-cid:12] Set(“IAX2/pittpbxiax-15662”, “CDR(source)=+1620687XXXX”) in new stack
[2022-03-01 10:08:55] VERBOSE[31432][C-00000144] pbx.c: Executing [s@sub-construct-cid:13] Return(“IAX2/pittpbxiax-15662”, “”) in new stack
[2022-03-01 10:08:55] VERBOSE[31432][C-00000144] pbx.c: Executing [s@cos-all:6] Gosub(“IAX2/pittpbxiax-15662”, “set-global-tenant-vars,s,1”) in new stack
[2022-03-01 10:08:55] VERBOSE[31432][C-00000144] pbx.c: Executing [s@set-global-tenant-vars:1] NoOp(“IAX2/pittpbxiax-15662”, “Setting Global Vars for vitalpbx Tenant”) in new stack
[2022-03-01 10:08:55] VERBOSE[31432][C-00000144] pbx.c: Executing [s@set-global-tenant-vars:2] Set(“IAX2/pittpbxiax-15662”, “__TENANT_PATH=27f1dbdefd9de0f4”) in new stack
[2022-03-01 10:08:55] VERBOSE[31432][C-00000144] pbx.c: Executing [s@set-global-tenant-vars:3] Set(“IAX2/pittpbxiax-15662”, “__TENANT_PREFIX=”) in new stack
[2022-03-01 10:08:55] VERBOSE[31432][C-00000144] pbx.c: Executing [s@set-global-tenant-vars:4] Set(“IAX2/pittpbxiax-15662”, “__QUEUE_AGENTS_CONTEXT=queue-call-to-agents”) in new stack
[2022-03-01 10:08:55] VERBOSE[31432][C-00000144] pbx.c: Executing [s@set-global-tenant-vars:5] Set(“IAX2/pittpbxiax-15662”, “__FOLLOWME_CONTEXT=ext-followme”) in new stack
[2022-03-01 10:08:55] VERBOSE[31432][C-00000144] pbx.c: Executing [s@set-global-tenant-vars:6] Set(“IAX2/pittpbxiax-15662”, “__HINTS_CONTEXT=extension-hints”) in new stack
[2022-03-01 10:08:55] VERBOSE[31432][C-00000144] pbx.c: Executing [s@set-global-tenant-vars:7] Set(“IAX2/pittpbxiax-15662”, “__DEFAULT_COS=cos-all”) in new stack
[2022-03-01 10:08:55] VERBOSE[31432][C-00000144] pbx.c: Executing [s@set-global-tenant-vars:8] Return(“IAX2/pittpbxiax-15662”, “”) in new stack
[2022-03-01 10:08:55] VERBOSE[31432][C-00000144] pbx.c: Executing [s@cos-all:7] GotoIf(“IAX2/pittpbxiax-15662”, “0?local-dialing”) in new stack
[2022-03-01 10:08:55] VERBOSE[31432][C-00000144] pbx.c: Executing [s@cos-all:8] NoOp(“IAX2/pittpbxiax-15662”, “Check if is an Emergency Call”) in new stack
[2022-03-01 10:08:55] VERBOSE[31432][C-00000144] pbx.c: Executing [s@cos-all:9] GotoIf(“IAX2/pittpbxiax-15662”, “0?emergency-calls,360785XXXX,1”) in new stack
[2022-03-01 10:08:55] VERBOSE[31432][C-00000144] pbx.c: Executing [s@cos-all:10] Gosub(“IAX2/pittpbxiax-15662”, “sub-lockphone-check,s,1”) in new stack
[2022-03-01 10:08:55] VERBOSE[31432][C-00000144] pbx.c: Executing [s@sub-lockphone-check:1] NoOp(“IAX2/pittpbxiax-15662”, “SUB: LOCK PHONE CHECK”) in new stack
[2022-03-01 10:08:55] VERBOSE[31432][C-00000144] pbx.c: Executing [s@sub-lockphone-check:2] GotoIf(“IAX2/pittpbxiax-15662”, “1?unlock”) in new stack
[2022-03-01 10:08:55] VERBOSE[31432][C-00000144] pbx_builtins.c: Goto (sub-lockphone-check,s,12)
[2022-03-01 10:08:55] VERBOSE[31432][C-00000144] pbx.c: Executing [s@sub-lockphone-check:12] Return(“IAX2/pittpbxiax-15662”, “”) in new stack
[2022-03-01 10:08:55] VERBOSE[31432][C-00000144] pbx.c: Executing [s@cos-all:11] Gosub(“IAX2/pittpbxiax-15662”, “sub-local-dialing,s,1”) in new stack
[2022-03-01 10:08:55] VERBOSE[31432][C-00000144] pbx.c: Executing [s@sub-local-dialing:1] NoOp(“IAX2/pittpbxiax-15662”, “Trying to determine if is a local extension”) in new stack
[2022-03-01 10:08:55] VERBOSE[31432][C-00000144] pbx.c: Executing [s@sub-local-dialing:2] GotoIf(“IAX2/pittpbxiax-15662”, “0?:return”) in new stack
[2022-03-01 10:08:55] VERBOSE[31432][C-00000144] pbx_builtins.c: Goto (sub-local-dialing,s,5)
[2022-03-01 10:08:55] VERBOSE[31432][C-00000144] pbx.c: Executing [s@sub-local-dialing:5] Return(“IAX2/pittpbxiax-15662”, “”) in new stack
[2022-03-01 10:08:55] VERBOSE[31432][C-00000144] pbx.c: Executing [s@cos-all:12] GotoIf(“IAX2/pittpbxiax-15662”, “0?end-call”) in new stack
[2022-03-01 10:08:55] VERBOSE[31432][C-00000144] pbx.c: Executing [s@cos-all:13] Goto(“IAX2/pittpbxiax-15662”, “cos-all-post,360785XXXX,1”) in new stack
[2022-03-01 10:08:55] VERBOSE[31432][C-00000144] pbx_builtins.c: Goto (cos-all-post,360785XXXX,1)
[2022-03-01 10:08:55] VERBOSE[31432][C-00000144] pbx.c: Executing [360785XXXX@cos-all-post:1] NoOp(“IAX2/pittpbxiax-15662”, “Outbound Route: AllOut”) in new stack
[2022-03-01 10:08:55] VERBOSE[31432][C-00000144] pbx.c: Executing [360785XXXX@cos-all-post:2] Gosub(“IAX2/pittpbxiax-15662”, “sub-setup-call-type,s,1(outgoing)”) in new stack
[2022-03-01 10:08:55] VERBOSE[31432][C-00000144] pbx.c: Executing [s@sub-setup-call-type:3] Gosub(“IAX2/pittpbxiax-15662”, “s-outgoing,1()”) in new stack
[2022-03-01 10:08:55] VERBOSE[31432][C-00000144] pbx.c: Executing [s-outgoing@sub-setup-call-type:1] NoOp(“IAX2/pittpbxiax-15662”, “Outgoing Call”) in new stack
[2022-03-01 10:08:55] VERBOSE[31432][C-00000144] pbx.c: Executing [s-outgoing@sub-setup-call-type:2] Set(“IAX2/pittpbxiax-15662”, “__CALL_TYPE=3”) in new stack
[2022-03-01 10:08:55] VERBOSE[31432][C-00000144] pbx.c: Executing [s-outgoing@sub-setup-call-type:3] Set(“IAX2/pittpbxiax-15662”, “__CALL_TYPE_LABEL=OUT”) in new stack
[2022-03-01 10:08:55] VERBOSE[31432][C-00000144] pbx.c: Executing [s-outgoing@sub-setup-call-type:4] GosubIf(“IAX2/pittpbxiax-15662”, “0?s-transit,1”) in new stack
[2022-03-01 10:08:55] VERBOSE[31432][C-00000144] pbx.c: Executing [s-outgoing@sub-setup-call-type:5] Return(“IAX2/pittpbxiax-15662”, “”) in new stack
[2022-03-01 10:08:55] VERBOSE[31432][C-00000144] pbx.c: Executing [s@sub-setup-call-type:5] Set(“IAX2/pittpbxiax-15662”, “CDR(calltype)=3”) in new stack
[2022-03-01 10:08:55] VERBOSE[31432][C-00000144] pbx.c: Executing [360785XXXX@cos-all-post:3] Set(“IAX2/pittpbxiax-15662”, “DNID=360785XXXX”) in new stack
[2022-03-01 10:08:55] VERBOSE[31432][C-00000144] pbx.c: Executing [360785XXXX@cos-all-post:4] NoOp(“IAX2/pittpbxiax-15662”, “Start to Dial Trunks”) in new stack
[2022-03-01 10:08:55] VERBOSE[31432][C-00000144] pbx.c: Executing [360785XXXX@cos-all-post:5] Goto(“IAX2/pittpbxiax-15662”, “s-1,1”) in new stack
[2022-03-01 10:08:55] VERBOSE[31432][C-00000144] pbx_builtins.c: Goto (cos-all-post,s-1,1)
[2022-03-01 10:08:55] VERBOSE[31432][C-00000144] pbx.c: Executing [s-1@cos-all-post:1] Set(“IAX2/pittpbxiax-15662”, “__CONFIGURED_BY_TENANT=yes”) in new stack
[2022-03-01 10:08:55] VERBOSE[31432][C-00000144] pbx.c: Executing [s-1@cos-all-post:2] Gosub(“IAX2/pittpbxiax-15662”, “sub-construct-cid,s-external,1”) in new stack
[2022-03-01 10:08:55] VERBOSE[31432][C-00000144] pbx.c: Executing [s-external@sub-construct-cid:1] NoOp(“IAX2/pittpbxiax-15662”, “Setting External CID”) in new stack
[2022-03-01 10:08:55] VERBOSE[31432][C-00000144] pbx.c: Executing [s-external@sub-construct-cid:2] Set(“IAX2/pittpbxiax-15662”, “EXTENSION_NUMBER=+1620687XXXX”) in new stack
[2022-03-01 10:08:55] VERBOSE[31432][C-00000144] pbx.c: Executing [s-external@sub-construct-cid:3] GotoIf(“IAX2/pittpbxiax-15662”, “0?return”) in new stack
[2022-03-01 10:08:55] VERBOSE[31432][C-00000144] pbx.c: Executing [s-external@sub-construct-cid:4] GotoIf(“IAX2/pittpbxiax-15662”, “0?return”) in new stack
[2022-03-01 10:08:55] VERBOSE[31432][C-00000144] pbx.c: Executing [s-external@sub-construct-cid:5] Set(“IAX2/pittpbxiax-15662”, “EMERGENCY_CALL=no”) in new stack
[2022-03-01 10:08:55] VERBOSE[31432][C-00000144] pbx.c: Executing [s-external@sub-construct-cid:6] Set(“IAX2/pittpbxiax-15662”, “EXTENSION_EMERGENCY_CID=”) in new stack
[2022-03-01 10:08:55] VERBOSE[31432][C-00000144] pbx.c: Executing [s-external@sub-construct-cid:7] Set(“IAX2/pittpbxiax-15662”, “DYNAMIC_EXTERNAL_CID=no”) in new stack
[2022-03-01 10:08:55] VERBOSE[31432][C-00000144] pbx.c: Executing [s-external@sub-construct-cid:8] ExecIf(“IAX2/pittpbxiax-15662”, “0?Set(EXTENSION_EMERGENCY_CID=)”) in new stack
[2022-03-01 10:08:55] VERBOSE[31432][C-00000144] pbx.c: Executing [s-external@sub-construct-cid:9] ExecIf(“IAX2/pittpbxiax-15662”, “0?Set(DYNAMIC_EXTERNAL_CID=)”) in new stack
[2022-03-01 10:08:55] VERBOSE[31432][C-00000144] pbx.c: Executing [s-external@sub-construct-cid:10] GotoIf(“IAX2/pittpbxiax-15662”, “0?check-emergency”) in new stack
[2022-03-01 10:08:55] VERBOSE[31432][C-00000144] pbx.c: Executing [s-external@sub-construct-cid:11] Set(“IAX2/pittpbxiax-15662”, “EXTENSION_EXTERNAL_CID=”) in new stack
[2022-03-01 10:08:55] VERBOSE[31432][C-00000144] pbx.c: Executing [s-external@sub-construct-cid:12] ExecIf(“IAX2/pittpbxiax-15662”, “0?Set(CALLERID(all)=)”) in new stack
[2022-03-01 10:08:55] VERBOSE[31432][C-00000144] pbx.c: Executing [s-external@sub-construct-cid:13] GotoIf(“IAX2/pittpbxiax-15662”, “0?:check-emergency”) in new stack
[2022-03-01 10:08:55] VERBOSE[31432][C-00000144] pbx_builtins.c: Goto (sub-construct-cid,s-external,16)
[2022-03-01 10:08:55] VERBOSE[31432][C-00000144] pbx.c: Executing [s-external@sub-construct-cid:16] GotoIf(“IAX2/pittpbxiax-15662”, “0?:info”) in new stack
[2022-03-01 10:08:55] VERBOSE[31432][C-00000144] pbx_builtins.c: Goto (sub-construct-cid,s-external,24)
[2022-03-01 10:08:55] VERBOSE[31432][C-00000144] pbx.c: Executing [s-external@sub-construct-cid:24] NoOp(“IAX2/pittpbxiax-15662”, “CID Name: +1620687XXXX, CID Number: +1620687XXXX”) in new stack
[2022-03-01 10:08:55] VERBOSE[31432][C-00000144] pbx.c: Executing [s-external@sub-construct-cid:25] Set(“IAX2/pittpbxiax-15662”, “SEND_CID=”) in new stack
[2022-03-01 10:08:55] VERBOSE[31432][C-00000144] pbx.c: Executing [s-external@sub-construct-cid:26] ExecIf(“IAX2/pittpbxiax-15662”, “0?Set(CALLERID(name-pres)=prohib_passed_screen)”) in new stack
[2022-03-01 10:08:55] VERBOSE[31432][C-00000144] pbx.c: Executing [s-external@sub-construct-cid:27] ExecIf(“IAX2/pittpbxiax-15662”, “0?Set(CALLERID(num-pres)=prohib_passed_screen)”) in new stack
[2022-03-01 10:08:55] VERBOSE[31432][C-00000144] pbx.c: Executing [s-external@sub-construct-cid:28] Set(“IAX2/pittpbxiax-15662”, “__EXT_CID_CONSTRUCTED=yes”) in new stack
[2022-03-01 10:08:55] VERBOSE[31432][C-00000144] pbx.c: Executing [s-external@sub-construct-cid:29] Set(“IAX2/pittpbxiax-15662”, “CDR(source)=+1620687XXXX”) in new stack
[2022-03-01 10:08:55] VERBOSE[31432][C-00000144] pbx.c: Executing [s-external@sub-construct-cid:30] Return(“IAX2/pittpbxiax-15662”, “”) in new stack
[2022-03-01 10:08:55] VERBOSE[31432][C-00000144] pbx.c: Executing [s-1@cos-all-post:3] Gosub(“IAX2/pittpbxiax-15662”, “trk-4,360785XXXX,1(from-trk-grp)”) in new stack
[2022-03-01 10:08:55] VERBOSE[31432][C-00000144] pbx.c: Executing [360785XXXX@trk-4:1] Set(“IAX2/pittpbxiax-15662”, “_NTD=360785XXXX”) in new stack
[2022-03-01 10:08:55] VERBOSE[31432][C-00000144] pbx.c: Executing [360785XXXX@trk-4:2] Gosub(“IAX2/pittpbxiax-15662”, “trk-4-dial,360785XXXX,1(from-trk-grp)”) in new stack
[2022-03-01 10:08:55] VERBOSE[31432][C-00000144] pbx.c: Executing [360785XXXX@trk-4-dial:1] NoOp(“IAX2/pittpbxiax-15662”, “Trunk: Pittpbxiax”) in new stack
[2022-03-01 10:08:55] VERBOSE[31432][C-00000144] pbx.c: Executing [360785XXXX@trk-4-dial:2] NoOp(“IAX2/pittpbxiax-15662”, “Dialing: 360785XXXX”) in new stack
[2022-03-01 10:08:55] VERBOSE[31432][C-00000144] pbx.c: Executing [360785XXXX@trk-4-dial:3] Set(“IAX2/pittpbxiax-15662”, “CDR(trunk)=4”) in new stack
[2022-03-01 10:08:55] VERBOSE[31432][C-00000144] pbx.c: Executing [360785XXXX@trk-4-dial:4] Set(“IAX2/pittpbxiax-15662”, “SKIP_HANGUP_AUDIOS=no”) in new stack
[2022-03-01 10:08:55] VERBOSE[31432][C-00000144] pbx.c: Executing [360785XXXX@trk-4-dial:5] Gosub(“IAX2/pittpbxiax-15662”, “sub-setup-call-type,s,1(outgoing,no)”) in new stack
[2022-03-01 10:08:55] VERBOSE[31432][C-00000144] pbx.c: Executing [s@sub-setup-call-type:3] Gosub(“IAX2/pittpbxiax-15662”, “s-outgoing,1(no)”) in new stack
[2022-03-01 10:08:55] VERBOSE[31432][C-00000144] pbx.c: Executing [360785XXXX@trk-4-dial:6] ExecIf(“IAX2/pittpbxiax-15662”, “0?Set(CALLERID(all)=):”) in new stack
[2022-03-01 10:08:55] VERBOSE[31432][C-00000144] pbx.c: Executing [360785XXXX@trk-4-dial:7] GotoIf(“IAX2/pittpbxiax-15662”, “0?:after-val-sim-calls”) in new stack
[2022-03-01 10:08:55] VERBOSE[31432][C-00000144] pbx_builtins.c: Goto (trk-4-dial,360785XXXX,18)
[2022-03-01 10:08:55] VERBOSE[31432][C-00000144] pbx.c: Executing [360785XXXX@trk-4-dial:18] NoOp(“IAX2/pittpbxiax-15662”, “”) in new stack
[2022-03-01 10:08:55] VERBOSE[31432][C-00000144] pbx.c: Executing [360785XXXX@trk-4-dial:19] NoOp(“IAX2/pittpbxiax-15662”, “Configuring Trunk Parameters”) in new stack
[2022-03-01 10:08:55] VERBOSE[31432][C-00000144] pbx.c: Executing [360785XXXX@trk-4-dial:20] ExecIf(“IAX2/pittpbxiax-15662”, “1?Set(CHANNEL(musicclass)=default):”) in new stack
[2022-03-01 10:08:55] VERBOSE[31432][C-00000144] pbx.c: Executing [360785XXXX@trk-4-dial:21] Set(“IAX2/pittpbxiax-15662”, “__TRUNK_MOH_SET=yes”) in new stack
[2022-03-01 10:08:55] VERBOSE[31432][C-00000144] pbx.c: Executing [360785XXXX@trk-4-dial:22] Set(“IAX2/pittpbxiax-15662”, “__TRKDIALOPTIONS=kKtr”) in new stack
[2022-03-01 10:08:55] VERBOSE[31432][C-00000144] pbx.c: Executing [360785XXXX@trk-4-dial:23] Set(“IAX2/pittpbxiax-15662”, “ORIGINATOR=+1620687XXXX”) in new stack
[2022-03-01 10:08:55] VERBOSE[31432][C-00000144] pbx.c: Executing [360785XXXX@trk-4-dial:24] Set(“IAX2/pittpbxiax-15662”, “RING_TIME=90”) in new stack
[2022-03-01 10:08:55] VERBOSE[31432][C-00000144] pbx.c: Executing [360785XXXX@trk-4-dial:25] Set(“IAX2/pittpbxiax-15662”, “CALLED=360785XXXX”) in new stack
[2022-03-01 10:08:55] VERBOSE[31432][C-00000144] pbx.c: Executing [360785XXXX@trk-4-dial:26] Set(“IAX2/pittpbxiax-15662”, “TRUNK_ENDPOINT=pittpbxiax”) in new stack
[2022-03-01 10:08:55] VERBOSE[31432][C-00000144] pbx.c: Executing [360785XXXX@trk-4-dial:27] Set(“IAX2/pittpbxiax-15662”, “__CIDNUM=+1620687XXXX”) in new stack
[2022-03-01 10:08:55] VERBOSE[31432][C-00000144] pbx.c: Executing [360785XXXX@trk-4-dial:28] Set(“IAX2/pittpbxiax-15662”, “__CIDNAME=+1620687XXXX”) in new stack
[2022-03-01 10:08:55] VERBOSE[31432][C-00000144] pbx.c: Executing [360785XXXX@trk-4-dial:29] Set(“IAX2/pittpbxiax-15662”, “FORCE_RECORDING=no”) in new stack
[2022-03-01 10:08:55] VERBOSE[31432][C-00000144] pbx.c: Executing [360785XXXX@trk-4-dial:30] Set(“IAX2/pittpbxiax-15662”, “FILTERED_NUMBER=360785XXXX”) in new stack
[2022-03-01 10:08:55] VERBOSE[31432][C-00000144] pbx.c: Executing [360785XXXX@trk-4-dial:31] GotoIf(“IAX2/pittpbxiax-15662”, “0?:post-fax”) in new stack
[2022-03-01 10:08:55] VERBOSE[31432][C-00000144] pbx_builtins.c: Goto (trk-4-dial,360785XXXX,34)
[2022-03-01 10:08:55] VERBOSE[31432][C-00000144] pbx.c: Executing [360785XXXX@trk-4-dial:34] NoOp(“IAX2/pittpbxiax-15662”, “End Fax Section”) in new stack
[2022-03-01 10:08:55] VERBOSE[31432][C-00000144] pbx.c: Executing [360785XXXX@trk-4-dial:35] Dial(“IAX2/pittpbxiax-15662”, “IAX2/pittpbxiax/360785XXXX,90,kKtrU(sub-call-recording^27f1dbdefd9de0f4^+1620687XXXX^360785XXXX^no)”) in new stack
[2022-03-01 10:08:55] VERBOSE[31432][C-00000144] app_dial.c: Called IAX2/pittpbxiax/360785XXXX
[2022-03-01 10:08:55] VERBOSE[2125][C-00000144] chan_iax2.c: Call accepted by 172.16.1.135:4569 (format alaw)
[2022-03-01 10:08:55] VERBOSE[2125][C-00000144] chan_iax2.c: Format for call is (alaw)
[2022-03-01 10:08:58] VERBOSE[2117] chan_iax2.c: Accepting AUTHENTICATED call from 172.16.1.135:4569:
