Hi
Wanted to check if this feature is already available or if there is a way so that a mobile or another external number is called when all extensions are unregistered/offline.
Basically in the event that say an internet outage occurs and all extensions can’t register that incoming calls automatically switch to call a mobile number or an external number and then when the extensions are online again it switches back to ringing like normal instead of the mobile/external number.
In our setup the PBX is running on a cloud server so isn’t located at the same site as all the phones.
