How can i block internal extension to extension calling but allow incoming and outgoing calls
Example the extension range is 101 to 115 and i want to block calling between each other
Using Vital PBX4
Using Vital PBX4
This should help you:
for example:
Scenario 5: Restricting calls by Prefix
and
https://wiki.vitalpbx.com/wiki/class-of-service/dialing-restriction-rules/
If you set an internal restriction rule, such as 1XX, then it blocks incoming calls as well.
