Hello everyone, is it possible to use the same extension on two devices, and if a call comes in, I can answer from either of the two devices?
If you use PJSIP, you can increase the maximum contacts and register more than 1 device.
With that being said, it is recommended to rather create an additional device under the same extension than using multiple contacts.
What are the advantages? Thanks.
- You can provision each device
- You can have different device profiles, very useful when one device is behind NAT and the other isn’t.
- You can set different dispatchable locations per device.
- You can control which device should ring for incoming calls
I’m sure that there’s more…
