We are getting the following Email sent to root@ourdomain, when I originally asked I was told we had installed a third party backup which I know we have not. So I set up an email account to collect the data and it seems pretty evident from the last line it is coming from the backup & restore module. Anyone know why it can’t find these files and what the fix would be?
Subject: Cron root@pbx1 /usr/share/vitalpbx/scripts/backups 1 3 “buildBackup1”
PHP Fatal error: Uncaught RuntimeException: tar: /var/spool/asterisk/voicemail/prosource_of_vero_beach-voicemail/200/INBOX/msg0006.txt: Cannot stat: No such file or directory
tar: /var/spool/asterisk/voicemail/prosource_of_vero_beach-voicemail/200/INBOX/msg0006.wav: Cannot stat: No such file or directory
tar: Exiting with failure status due to previous errors
tar: /var/spool/asterisk/voicemail/united_against_poverty-voicemail/202/INBOX/msg0045.txt: Cannot stat: No such file or directory
tar: /var/spool/asterisk/voicemail/united_against_poverty-voicemail/202/INBOX/msg0045.wav: Cannot stat: No such file or directory
tar: /var/spool/asterisk/voicemail/united_against_poverty-voicemail/201/INBOX/msg0007.txt: Cannot stat: No such file or directory
tar: /var/spool/asterisk/voicemail/united_against_poverty-voicemail/201/INBOX/msg0007.wav: Cannot stat: No such file or directory
tar: /var/spool/asterisk/voicemail/united_against_poverty-voicemail/207/Deleted/msg0021.txt: Cannot stat: No such file or directory
tar: /var/spool/asterisk/vo in /usr/share/vitalpbx/www/modules/backup_and_restore/backup_and_restore.php on line 0
