Authorization Failure for Zoho CRM Connector (AU region
Zoho CRM integration does not work when using the Australia region (zoho.com.au).
When attempting to authorize the connector for the AU region, the process hangs and the authentication pop-up window fails to appear. This functionality is working correctly for all other regions, where the pop-up opens as expected.
Steps to Reproduce:
  1. Select the Zoho CRM Connector.
  2. Set the region/datacenter to AU and fill zoho secret and client id
  3. Click on Authorize.
  4. The process stays stuck/loading without launching the authentication window.
Could you please investigate this region-specific bug and provide an update on a fix?
Thanks for reporting it. We will check it
Thanks miguel, is there any time frame for the fix ?
You can update the add-on from the add-ons module to get the fix. By the way, do not forget to click “Check Updates” to retrieve the available updates.
