Hi all,
I am trying to install VitalPBX 4 on Debian but keep running it the following:
* Installing VitalPBX packages and Firewall... *
Reading package lists... Done
Building dependency tree... Done
Reading state information... Done
Package asterisk-pbx is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
I have tried installing Asterisk manually but am getting the same result. Any advice would be greatly appreciated.
More details:
Waiting for cache lock: Could not get lock /var/lib/dpkg/lock-frontend. It is held by process 80400 (apt-get)
firewalld is already the newest version (1.3.3-1~deb12u1).
fail2ban is already the newest version (1.0.2-2).
iptables is already the newest version (1.8.9-2).
iptables-persistent is already the newest version (1.0.20).
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
asterisk-pbx-modules : Depends: libcodec2-0.9 (>= 0.9.2) but it is not installable
Depends: libssl1.1 (>= 1.1.1) but 1.1.0l-1~deb9u1 is to be installed
E: Unable to correct problems, you have held broken packages.
