pbx-a.bellqconnect.nl Carrier Plus 3.1.5-4
Asterisk 18.6.0-1
DAHDI 2.11.1-7
Asterisk ERROR[25967] res_pjsip.c: Unable to retrieve PJSIP transport ‘transport-udp’ since upgrade to 3.1.5-4
Asterisk stopped working correcly, after a reset of asterisk it works again, but I see errors.
In the GUI there is a new Item under “Technology Settings” called “PJSIP Transports”.
In “PJSIP Transports” there are no configs.
I notice that there is an extra file “/etc/asterisk/vitalpbx/pjsip__40-1-profiles.conf”
The file has configs:
After setting all trunks of all the tennants to disable en then back to enable the problems seems solved.
The problem was that on incomming calls from trunks this error was created in asterisk and asterisk refused the calls.
I updated to latest VitalPBX 3.1.6-1 with Asterisk 18.10.0
Created a new PJSIP Devices and got “rejected” when trying to dial out. Internal numbers same thing: REJECTED.
Dialing in was never a problem.
I changed to TCP instead of UDP on the Fanvil X6U and then i was able to dial out.
But then: PJSIP Endpoints in PBX Reports show RED on Contacts because of TCP.
“Default PJSIP Profile” transport is still UDP like it always was.
MicroSIP Softphone is working fine on UDP. This Fanvil X6U even after factory defaults not working fine.
Sound like this could effect many in the future so this should be taken seriously.
The transports are now created dynamically. What I meant is that the transport with the name “transport-udp” doesn’t exist. Instead, there’s a UDP transport with a random name.
If you execute the command below, you will see the list of available transports.
The problem was that the update did not update the asterisk files for the tenants.
After disable and enable the trunks for the tenants new asterisk files where made and the problem was solved. It could have been caused by a copy of a http conf file (my fault) which caused an error after the update (double ports) so the http server did not start automatically after the update.
Maybe the asterisk files for the tenants where not renewed due to the http server was not working?
Just a quick feedback:
must be an issue with this Fanvil phone not with VitalPBX. Fanvil X6U has been nice but this one phone is driving me nuts. If there are strange things with Fanvil phones even after factory defaults: try a different fanvil phone.
