Asterisk CLI command
I have a call that is stuck between two extensions under the same tenant.
I am wanting to terminate the call in the asterisk CLI.
I can do command “pjsip show channels” to see the call, but I am not sure which is the channel ID to select to actually terminate that specific call or how to use the command to terminate it.
Channel: PJSIP/FarmB1067-0000c2c4/ParkedCall Up 26:15:57
Exten: s CLCID: “Julia” <320>
Channel: PJSIP/FarmB320-0000c2be/Park Up 26:16:24
Exten: 700 CLCID: “Aubrey” <1067>
This call is the one I need to terminate.
Do I use this command this way: “channel request hangup PJSIP/FarmB1067-0000c2c4/ParkedCall”
Or is it: “channel request hangup “Julia” <320>”
Or are neither of those correct? Just not sure how to select that specific channel to hang up.
Google: asterisk pjsip hangup command
Result:
Does this not help you?
Yep.That would have helped. But I figured it out after messing with it a little bit more yesterday.
For future users who may need it and find this post
pjsip show channels
And that article mo10 posted shows the command
