AI Voice Profile with OpenAI.
Currently there is: “Alloy, Echo, Fable, Onyx, Nova, Shimmer”
Looking to add a few UK female voices.
Ideally like option to add new voices or at least increase selection.
The AI features are amazing otherwise and voice transcription with open AI works so well!
Hello there!
That depends on OpenAI.
I asked Maynor P from support and he said “Currently, you can only use the voices listed in the Voice Profiles.” ? - Is there a way I can add it via OpenAI ? Is there another way? Some clues?
Again, that depends on OpenAI.
About the Voice Profiles, you can configure/connect Microsoft to have more voice options.
Thanks - ill check out the Microsoft AI options until more becomes available on OpenAI.
