Is there a way to customize VitXi’s color scheme, or brand it in anyway?
You can modify the logo and the default app name with the branding module!
Regards!
I could be wrong but under branding none of this seems to affect the VitXi WebRTC application.
this feature is only available with the Carrier Plus plan
Would the VitalPBX One Plan not include that?
It is also included in the VitalPBX One!
Ah ok, then there must be a bug because the only thing to brand is VitalPBX and not VitXi
In the branding module, does the “addons” tab appear?
No there isn’t,
only General, GUI, and Login Design.
ohh ok, I will report it to the team,
Do we have any updates on this?
We are about to purchase VitalPBX One license and wants to confirm first.
Sorry for the delay in the response,
What version of VitalPBX do you have installed?
@maynor - using the latest version - 4.1.0-8
I have installed Sonata Suites also. Please send us guide on how to change the branding on Vitxi and Sonata Suites. I don’t see any options to change branding.
Could you please try the following steps:
Also, could you please check if, after refreshing VitalPBX using CTRL + F5, the “Addon” tab still does not appear?:
Regarding color customization, there is currently no option to personalize VitXi’s colors. However, we will discuss this with the team for future consideration.
