4.0.6-2 cron error on Storage Notifications
made a fresh VitalPBX install yesterday with debian 11.8.0 netinst. Then used the githup VPS skript.
4.0.6-2 now.
One problem:
i set up email settings and everything is fine.
I added Email on Storage Notifications.
and now i get this email ever hour:
Subject:
Cron <root@xyzpbx> cd / && run-parts --report /etc/cron.hourly
[email protected] (Cron Daemon)
Date:
08.11.2023, 09:17
Tp:
[email protected]
/etc/cron.hourly/vpbx_check_disk:
/etc/cron.hourly/vpbx_check_disk: 3: [[: not found
I have not check the other notifications.
Can you please help / Fix? Thanks
Even disabled the notification now but because of this error i still get that email every hour, which is very annoying:
Looks like the Problem are the [[ and ]]
With only [ and ] the “run-parts --report /etc/cron.hourly” runs fine.
Hi, any feedback on this?
Fix in next version?
I just reply to myself again:
Should be fixed in 4.0.6 R3
