VitalPbx Provision Error on Flyingvoice phone.pdf (252.7 KB)
After try provision using Flyingvoice FIP10P, found some error.
How to resolved it ?
Hi @NGIA_Soon_Hock welcome to the community!
In the future, please document and upload the pictures directly to the forum.
This seems to be a bug. As a workaround, you can set the secondary account under the custom tab.
Could you please attach the files located at /usr/share/provisioning/storage/logs/ for debugging.
I am managed to ask Flyingvoice Engineer modified custom Template is work now
Great, but in order to fix this, please reply to @Roger with the information he asked. Thank you
Problem resolved without my debugging, I just forward to Flyingvoice engineer just ask them to do custom template .If you need the custom template. Update me, I will forward to you.
No. @Roger is on the VitalPBX team. The team is constantly looking out to improve and fix VitalPBX.
If you provide him the information he asked, they may be able to fix this issue.
Hi @NGIA_Soon_Hock, It looks like this issue is resolved in the latest version. Can you please confirm?
resolved via custom template not the latest version. I just update the latest version. will test and update
Are this change https default port to any ports when update provision port will have such error , are vitalpbx current bugs ?
