Hello, we have a sip trunk where the provider sends in international standard. in our case Brazil +551144441234
I created an inbound route informing the DID +551144441234 and directing to a specific extension.
but when I receive the call I get the error
Executing [s@invalid-dest:1] NoOp(“SIP/sip-00000000”, “Invalid Route to Dial”) in new stack
I also tried to create at all with the did 551144441234 and the same problem.
when creating a route without informing the DID it works normally.
below log
Note: Origin +551122229988 destination +551144441234 It is an incoming call
[2021-10-21 22:02:31] VERBOSE[7407][C-00000001] pbx.c: Executing [1144441234@trk-1-in:1] NoOp("SIP/sip-00000000", "Incoming call through: VIVO SIP") in new stack
[2021-10-21 22:02:31] VERBOSE[7407][C-00000001] pbx.c: Executing [1144441234@trk-1-in:2] Set("SIP/sip-00000000", "__TRUNK_ID=1") in new stack
[2021-10-21 22:02:31] VERBOSE[7407][C-00000001] pbx.c: Executing [1144441234@trk-1-in:3] Set("SIP/sip-00000000", "CDR(trunk)=1") in new stack
[2021-10-21 22:02:31] VERBOSE[7407][C-00000001] pbx.c: Executing [1144441234@trk-1-in:4] Set("SIP/sip-00000000", "__DID_NUMBER=1144441234") in new stack
[2021-10-21 22:02:31] VERBOSE[7407][C-00000001] pbx.c: Executing [1144441234@trk-1-in:5] Set("SIP/sip-00000000", "CDR(did)=1144441234") in new stack
[2021-10-21 22:02:31] VERBOSE[7407][C-00000001] pbx.c: Executing [1144441234@trk-1-in:6] Set("SIP/sip-00000000", "DID=1144441234") in new stack
[2021-10-21 22:02:31] VERBOSE[7407][C-00000001] pbx.c: Executing [1144441234@trk-1-in:7] Goto("SIP/sip-00000000", "default-trunk,1144441234,1") in new stack
[2021-10-21 22:02:31] VERBOSE[7407][C-00000001] pbx_builtins.c: Goto (default-trunk,1144441234,1)
[2021-10-21 22:02:31] VERBOSE[7407][C-00000001] pbx.c: Executing [1144441234@default-trunk:1] Gosub("SIP/sip-00000000", "set-global-tenant-vars,s,1") in new stack
[2021-10-21 22:02:31] VERBOSE[7407][C-00000001] pbx.c: Executing [s@set-global-tenant-vars:1] NoOp("SIP/sip-00000000", "Setting Global Vars for vitalpbx Tenant") in new stack
[2021-10-21 22:02:31] VERBOSE[7407][C-00000001] pbx.c: Executing [s@set-global-tenant-vars:2] Set("SIP/sip-00000000", "__TENANT_PATH=00fdbc826423c4b6") in new stack
[2021-10-21 22:02:31] VERBOSE[7407][C-00000001] pbx.c: Executing [s@set-global-tenant-vars:3] Set("SIP/sip-00000000", "__TENANT_PREFIX=") in new stack
[2021-10-21 22:02:31] VERBOSE[7407][C-00000001] pbx.c: Executing [s@set-global-tenant-vars:4] Set("SIP/sip-00000000", "__QUEUE_AGENTS_CONTEXT=queue-call-to-agents") in new stack
[2021-10-21 22:02:31] VERBOSE[7407][C-00000001] pbx.c: Executing [s@set-global-tenant-vars:5] Set("SIP/sip-00000000", "__FOLLOWME_CONTEXT=ext-followme") in new stack
[2021-10-21 22:02:31] VERBOSE[7407][C-00000001] pbx.c: Executing [s@set-global-tenant-vars:6] Set("SIP/sip-00000000", "__HINTS_CONTEXT=extension-hints") in new stack
[2021-10-21 22:02:31] VERBOSE[7407][C-00000001] pbx.c: Executing [s@set-global-tenant-vars:7] Set("SIP/sip-00000000", "__DEFAULT_COS=cos-all") in new stack
[2021-10-21 22:02:31] VERBOSE[7407][C-00000001] pbx.c: Executing [s@set-global-tenant-vars:8] Return("SIP/sip-00000000", "") in new stack
[2021-10-21 22:02:31] VERBOSE[7407][C-00000001] pbx.c: Executing [1144441234@default-trunk:2] Gosub("SIP/sip-00000000", "sub-check-blacklist,s,1(00fdbc826423c4b6,+551122229988)") in new stack
[2021-10-21 22:02:31] VERBOSE[7407][C-00000001] pbx.c: Executing [s@sub-check-blacklist:1] NoOp("SIP/sip-00000000", "Testing if +551122229988 is in Black List") in new stack
[2021-10-21 22:02:31] VERBOSE[7407][C-00000001] pbx.c: Executing [s@sub-check-blacklist:2] GotoIf("SIP/sip-00000000", "0?banned") in new stack
[2021-10-21 22:02:31] VERBOSE[7407][C-00000001] pbx.c: Executing [s@sub-check-blacklist:3] Return("SIP/sip-00000000", "") in new stack
[2021-10-21 22:02:31] VERBOSE[7407][C-00000001] pbx.c: Executing [1144441234@default-trunk:3] Gosub("SIP/sip-00000000", "sub-setup-call-type,s,1(incoming)") in new stack
[2021-10-21 22:02:31] VERBOSE[7407][C-00000001] pbx.c: Executing [s@sub-setup-call-type:1] NoOp("SIP/sip-00000000", "Determinating Call Type") in new stack
[2021-10-21 22:02:31] VERBOSE[7407][C-00000001] pbx.c: Executing [s@sub-setup-call-type:2] GotoIf("SIP/sip-00000000", "0?return") in new stack
[2021-10-21 22:02:31] VERBOSE[7407][C-00000001] pbx.c: Executing [s@sub-setup-call-type:3] Gosub("SIP/sip-00000000", "s-incoming,1()") in new stack
[2021-10-21 22:02:31] VERBOSE[7407][C-00000001] pbx.c: Executing [s-incoming@sub-setup-call-type:1] NoOp("SIP/sip-00000000", "Incoming Call") in new stack
[2021-10-21 22:02:31] VERBOSE[7407][C-00000001] pbx.c: Executing [s-incoming@sub-setup-call-type:2] Set("SIP/sip-00000000", "__CALL_TYPE=2") in new stack
[2021-10-21 22:02:31] VERBOSE[7407][C-00000001] pbx.c: Executing [s-incoming@sub-setup-call-type:3] Set("SIP/sip-00000000", "__CALL_TYPE_LABEL=IN") in new stack
[2021-10-21 22:02:31] VERBOSE[7407][C-00000001] pbx.c: Executing [s-incoming@sub-setup-call-type:4] Return("SIP/sip-00000000", "") in new stack
[2021-10-21 22:02:31] VERBOSE[7407][C-00000001] pbx.c: Executing [s@sub-setup-call-type:4] Set("SIP/sip-00000000", "__CALL_TYPE_CONFIGURED=yes") in new stack
[2021-10-21 22:02:31] VERBOSE[7407][C-00000001] pbx.c: Executing [s@sub-setup-call-type:5] Set("SIP/sip-00000000", "CDR(calltype)=2") in new stack
[2021-10-21 22:02:31] VERBOSE[7407][C-00000001] pbx.c: Executing [s@sub-setup-call-type:6] Return("SIP/sip-00000000", "") in new stack
[2021-10-21 22:02:31] VERBOSE[7407][C-00000001] pbx.c: Executing [1144441234@default-trunk:4] Gosub("SIP/sip-00000000", "dynamic-routing-in,s,1(+551122229988)") in new stack
[2021-10-21 22:02:31] VERBOSE[7407][C-00000001] pbx.c: Executing [s@dynamic-routing-in:1] NoOp("SIP/sip-00000000", "Test if must to apply dynamic routing") in new stack
[2021-10-21 22:02:31] VERBOSE[7407][C-00000001] pbx.c: Executing [s@dynamic-routing-in:2] Set("SIP/sip-00000000", "EXTERNAL_CALLER=+551122229988") in new stack
[2021-10-21 22:02:31] VERBOSE[7407][C-00000001] pbx.c: Executing [s@dynamic-routing-in:3] Set("SIP/sip-00000000", "DYNROUTING_DM=0") in new stack
[2021-10-21 22:02:31] VERBOSE[7407][C-00000001] pbx.c: Executing [s@dynamic-routing-in:4] GotoIf("SIP/sip-00000000", "1?gd") in new stack
[2021-10-21 22:02:31] VERBOSE[7407][C-00000001] pbx_builtins.c: Goto (dynamic-routing-in,s,6)
[2021-10-21 22:02:31] VERBOSE[7407][C-00000001] pbx.c: Executing [s@dynamic-routing-in:6] GotoIf("SIP/sip-00000000", "0?:rb") in new stack
[2021-10-21 22:02:31] VERBOSE[7407][C-00000001] pbx_builtins.c: Goto (dynamic-routing-in,s,11)
[2021-10-21 22:02:31] VERBOSE[7407][C-00000001] pbx.c: Executing [s@dynamic-routing-in:11] Return("SIP/sip-00000000", "") in new stack
[2021-10-21 22:02:31] VERBOSE[7407][C-00000001] pbx.c: Executing [1144441234@default-trunk:5] Goto("SIP/sip-00000000", "incoming-calls,1144441234,1") in new stack
[2021-10-21 22:02:31] VERBOSE[7407][C-00000001] pbx_builtins.c: Goto (incoming-calls,1144441234,1)
[2021-10-21 22:02:31] VERBOSE[7407][C-00000001] pbx.c: Channel 'SIP/sip-00000000' sent to invalid extension: context,exten,priority=incoming-calls,1144441234,1
[2021-10-21 22:02:31] VERBOSE[7407][C-00000001] pbx.c: Executing [i@incoming-calls:1] NoCDR("SIP/sip-00000000", "") in new stack
[2021-10-21 22:02:31] VERBOSE[7407][C-00000001] pbx.c: Executing [i@incoming-calls:2] Goto("SIP/sip-00000000", "invalid-dest,s,1") in new stack
[2021-10-21 22:02:31] VERBOSE[7407][C-00000001] pbx_builtins.c: Goto (invalid-dest,s,1)
[2021-10-21 22:02:31] VERBOSE[7407][C-00000001] pbx.c: Executing [s@invalid-dest:1] NoOp("SIP/sip-00000000", "Invalid Route to Dial") in new stack
[2021-10-21 22:02:31] VERBOSE[7407][C-00000001] pbx.c: Executing [s@invalid-dest:2] GotoIf("SIP/sip-00000000", "0?end") in new stack
[2021-10-21 22:02:31] VERBOSE[7407][C-00000001] pbx.c: Executing [s@invalid-dest:3] Playback("SIP/sip-00000000", "im-sorry&no-route-exists-to-dest&vm-goodbye") in new stack
[2021-10-21 22:02:32] VERBOSE[7407][C-00000001] res_rtp_asterisk.c: 0x7f4ec0005fb0 -- Strict RTP switching to RTP target address 10.255.240.112:36700 as source
