All added in sub tenant (T5), dialed 9001 from extension 51001, call is being disconnected
Context :
[email-notify-DM]
exten=> _.,1,Set(user=admin)
same=>n,Set(Answer=${CURL(https://example.com/admin/client_data_received?client_id="${CALLERID(number)}"&token=adFki1234861252235fgh1))
same=>n,Goto(${ARG1},${ARG2},${ARG3})
Logs
[2021-11-19 02:06:14] NOTICE[9731]: app_queue.c:9162 reload_queue_rules: No queuerules.conf file found, queues will not follow penalty rules
-- Executing [9001@T5_cos-all:1] NoOp("PJSIP/T5_51001-0000003c", "More than on digit pattern") in new stack
-- Executing [9001@T5_cos-all:2] Gosub("PJSIP/T5_51001-0000003c", "s,1(9001)") in new stack
-- Executing [s@T5_cos-all:1] Set("PJSIP/T5_51001-0000003c", "EXTENSION=9001") in new stack
-- Executing [s@T5_cos-all:2] NoOp("PJSIP/T5_51001-0000003c", "Dialing 9001 from 51001") in new stack
-- Executing [s@T5_cos-all:3] Gosub("PJSIP/T5_51001-0000003c", "sub-set-global-vars,s,1(5414c1540305ca71,9001,parking-5)") in new stack
-- Executing [s@sub-set-global-vars:1] NoOp("PJSIP/T5_51001-0000003c", "Setting Global Vars") in new stack
-- Executing [s@sub-set-global-vars:2] Set("PJSIP/T5_51001-0000003c", "TENANT_PATH=5414c1540305ca71") in new stack
-- Executing [s@sub-set-global-vars:3] Set("PJSIP/T5_51001-0000003c", "PREFIX=T5_") in new stack
-- Executing [s@sub-set-global-vars:4] Set("PJSIP/T5_51001-0000003c", "__PICKUPMARK=T5_9001") in new stack
-- Executing [s@sub-set-global-vars:5] Set("PJSIP/T5_51001-0000003c", "__PARKINGLOT=parking-5") in new stack
-- Executing [s@sub-set-global-vars:6] Set("PJSIP/T5_51001-0000003c", "__DYNAMIC_FEATURES=custom-features") in new stack
-- Executing [s@sub-set-global-vars:7] Set("PJSIP/T5_51001-0000003c", "ICALL=no") in new stack
-- Executing [s@sub-set-global-vars:8] Return("PJSIP/T5_51001-0000003c", "") in new stack
-- Executing [s@T5_cos-all:4] Gosub("PJSIP/T5_51001-0000003c", "sub-set-call-vars,s,1(5414c1540305ca71,9001,5,T5_cos-all,T5_ARS-all)") in new stack
-- Executing [s@sub-set-call-vars:1] NoOp("PJSIP/T5_51001-0000003c", "Setting Call Vars") in new stack
-- Executing [s@sub-set-call-vars:2] Set("PJSIP/T5_51001-0000003c", "_TENANT=5414c1540305ca71") in new stack
-- Executing [s@sub-set-call-vars:3] Set("PJSIP/T5_51001-0000003c", "_CALL_DESTINATION=9001") in new stack
-- Executing [s@sub-set-call-vars:4] Set("PJSIP/T5_51001-0000003c", "_COS_ID=5") in new stack
-- Executing [s@sub-set-call-vars:5] Set("PJSIP/T5_51001-0000003c", "_COS_NAME=T5_cos-all") in new stack
-- Executing [s@sub-set-call-vars:6] Set("PJSIP/T5_51001-0000003c", "__TRANSFER_CONTEXT=T5_cos-all") in new stack
-- Executing [s@sub-set-call-vars:7] Set("PJSIP/T5_51001-0000003c", "_ARS=T5_ARS-all") in new stack
-- Executing [s@sub-set-call-vars:8] Set("PJSIP/T5_51001-0000003c", "CDR(tenant)=spectrum") in new stack
-- Executing [s@sub-set-call-vars:9] Set("PJSIP/T5_51001-0000003c", "CDR(destination)=9001") in new stack
-- Executing [s@sub-set-call-vars:10] Set("PJSIP/T5_51001-0000003c", "CDR(trunk)=") in new stack
-- Executing [s@sub-set-call-vars:11] Set("PJSIP/T5_51001-0000003c", "CDR(did)=") in new stack
-- Executing [s@sub-set-call-vars:12] Set("PJSIP/T5_51001-0000003c", "__CALLID=1637283983.144") in new stack
-- Executing [s@sub-set-call-vars:13] ExecIf("PJSIP/T5_51001-0000003c", "0?Set(CHANNEL(language)=)") in new stack
-- Executing [s@sub-set-call-vars:14] Return("PJSIP/T5_51001-0000003c", "") in new stack
-- Executing [s@T5_cos-all:5] Gosub("PJSIP/T5_51001-0000003c", "sub-construct-cid,s,1") in new stack
-- Executing [s@sub-construct-cid:1] NoOp("PJSIP/T5_51001-0000003c", "Building CID") in new stack
-- Executing [s@sub-construct-cid:2] Set("PJSIP/T5_51001-0000003c", "_CALL_SOURCE=51001") in new stack
-- Executing [s@sub-construct-cid:3] Set("PJSIP/T5_51001-0000003c", "_CS=51001") in new stack
-- Executing [s@sub-construct-cid:4] GotoIf("PJSIP/T5_51001-0000003c", "0?return") in new stack
-- Executing [s@sub-construct-cid:5] Gosub("PJSIP/T5_51001-0000003c", "sub-get-device-tree,s,1") in new stack
-- Executing [s@sub-get-device-tree:1] NoOp("PJSIP/T5_51001-0000003c", "Configuring Device Tree") in new stack
-- Executing [s@sub-get-device-tree:2] Set("PJSIP/T5_51001-0000003c", "DEV_TECHNOLOGY=PJSIP") in new stack
-- Executing [s@sub-get-device-tree:3] GosubIf("PJSIP/T5_51001-0000003c", "0?s-local,1") in new stack
-- Executing [s@sub-get-device-tree:4] GotoIf("PJSIP/T5_51001-0000003c", "0?return") in new stack
-- Executing [s@sub-get-device-tree:5] GotoIf("PJSIP/T5_51001-0000003c", "1?pjsip") in new stack
-- Goto (sub-get-device-tree,s,9)
-- Executing [s@sub-get-device-tree:9] NoOp("PJSIP/T5_51001-0000003c", "A PJSIP") in new stack
-- Executing [s@sub-get-device-tree:10] Set("PJSIP/T5_51001-0000003c", "DEV_USER=T5_51001") in new stack
-- Executing [s@sub-get-device-tree:11] Goto("PJSIP/T5_51001-0000003c", "build_interface") in new stack
-- Goto (sub-get-device-tree,s,13)
-- Executing [s@sub-get-device-tree:13] Set("PJSIP/T5_51001-0000003c", "_INTERFACE=PJSIP/T5_51001") in new stack
-- Executing [s@sub-get-device-tree:14] Set("PJSIP/T5_51001-0000003c", "DEV_TREE=devices/PJSIP/T5_51001") in new stack
-- Executing [s@sub-get-device-tree:15] Return("PJSIP/T5_51001-0000003c", "") in new stack
-- Executing [s@sub-construct-cid:6] GotoIf("PJSIP/T5_51001-0000003c", "0?return") in new stack
-- Executing [s@sub-construct-cid:7] Set("PJSIP/T5_51001-0000003c", "_CALL_SOURCE=51001") in new stack
-- Executing [s@sub-construct-cid:8] Set("PJSIP/T5_51001-0000003c", "_CS=51001") in new stack
-- Executing [s@sub-construct-cid:9] ExecIf("PJSIP/T5_51001-0000003c", "1?Set(CALLERID(all)="Test 51001" <51001>)") in new stack
-- Executing [s@sub-construct-cid:10] Set("PJSIP/T5_51001-0000003c", "_CID_CONSTRUCTED=yes") in new stack
-- Executing [s@sub-construct-cid:11] NoOp("PJSIP/T5_51001-0000003c", "") in new stack
-- Executing [s@sub-construct-cid:12] Set("PJSIP/T5_51001-0000003c", "CDR(source)=51001") in new stack
-- Executing [s@sub-construct-cid:13] Return("PJSIP/T5_51001-0000003c", "") in new stack
-- Executing [s@T5_cos-all:6] Gosub("PJSIP/T5_51001-0000003c", "T5_set-global-tenant-vars,s,1") in new stack
-- Executing [s@T5_set-global-tenant-vars:1] NoOp("PJSIP/T5_51001-0000003c", "Setting Global Vars for spectrum Tenant") in new stack
-- Executing [s@T5_set-global-tenant-vars:2] Set("PJSIP/T5_51001-0000003c", "__TENANT_PATH=5414c1540305ca71") in new stack
-- Executing [s@T5_set-global-tenant-vars:3] Set("PJSIP/T5_51001-0000003c", "__TENANT_PREFIX=T5_") in new stack
-- Executing [s@T5_set-global-tenant-vars:4] Set("PJSIP/T5_51001-0000003c", "__QUEUE_AGENTS_CONTEXT=T5_queue-call-to-agents") in new stack
-- Executing [s@T5_set-global-tenant-vars:5] Set("PJSIP/T5_51001-0000003c", "__FOLLOWME_CONTEXT=T5_ext-followme") in new stack
-- Executing [s@T5_set-global-tenant-vars:6] Set("PJSIP/T5_51001-0000003c", "__HINTS_CONTEXT=T5_extension-hints") in new stack
-- Executing [s@T5_set-global-tenant-vars:7] Set("PJSIP/T5_51001-0000003c", "__DEFAULT_COS=T5_cos-all") in new stack
-- Executing [s@T5_set-global-tenant-vars:8] Return("PJSIP/T5_51001-0000003c", "") in new stack
-- Executing [s@T5_cos-all:7] GotoIf("PJSIP/T5_51001-0000003c", "0?local-dialing") in new stack
-- Executing [s@T5_cos-all:8] NoOp("PJSIP/T5_51001-0000003c", "Check if is an Emergency Call") in new stack
-- Executing [s@T5_cos-all:9] GotoIf("PJSIP/T5_51001-0000003c", "0?T5_emergency-calls,9001,1") in new stack
-- Executing [s@T5_cos-all:10] Gosub("PJSIP/T5_51001-0000003c", "sub-lockphone-check,s,1") in new stack
-- Executing [s@sub-lockphone-check:1] NoOp("PJSIP/T5_51001-0000003c", "SUB: LOCK PHONE CHECK") in new stack
-- Executing [s@sub-lockphone-check:2] GotoIf("PJSIP/T5_51001-0000003c", "0?unlock") in new stack
-- Executing [s@sub-lockphone-check:3] GotoIf("PJSIP/T5_51001-0000003c", "0?unlock") in new stack
-- Executing [s@sub-lockphone-check:4] GotoIf("PJSIP/T5_51001-0000003c", "0?unlock") in new stack
-- Executing [s@sub-lockphone-check:5] GotoIf("PJSIP/T5_51001-0000003c", "0?unlock") in new stack
-- Executing [s@sub-lockphone-check:6] GotoIf("PJSIP/T5_51001-0000003c", "0?:unlock") in new stack
-- Executing [s@sub-lockphone-check:12] Return("PJSIP/T5_51001-0000003c", "") in new stack
-- Executing [s@T5_cos-all:11] Gosub("PJSIP/T5_51001-0000003c", "sub-local-dialing,s,1") in new stack
-- Executing [s@sub-local-dialing:1] NoOp("PJSIP/T5_51001-0000003c", "Trying to determine if is a local extension") in new stack
-- Executing [s@sub-local-dialing:2] GotoIf("PJSIP/T5_51001-0000003c", "0?:return") in new stack
-- Executing [s@sub-local-dialing:5] Return("PJSIP/T5_51001-0000003c", "") in new stack
-- Executing [s@T5_cos-all:12] GotoIf("PJSIP/T5_51001-0000003c", "0?end-call") in new stack
-- Executing [s@T5_cos-all:13] Set("PJSIP/T5_51001-0000003c", "OUTBOUND_PROFILE=") in new stack
-- Executing [s@T5_cos-all:14] GotoIf("PJSIP/T5_51001-0000003c", "1?post-dialing") in new stack
-- Goto (T5_cos-all,s,16)
-- Executing [s@T5_cos-all:16] Goto("PJSIP/T5_51001-0000003c", "T5_cos-all-post,9001,1") in new stack
-- Goto (T5_cos-all-post,9001,1)
-- Executing [9001@T5_cos-all-post:1] Gosub("PJSIP/T5_51001-0000003c", "sub-set-call-vars,app-incoming,1") in new stack
-- Executing [app-incoming@sub-set-call-vars:1] NoOp("PJSIP/T5_51001-0000003c", "Incoming Call App CDR") in new stack
-- Executing [app-incoming@sub-set-call-vars:2] GotoIf("PJSIP/T5_51001-0000003c", "0?:return") in new stack
-- Goto (sub-set-call-vars,app-incoming,6)
-- Executing [app-incoming@sub-set-call-vars:6] Return("PJSIP/T5_51001-0000003c", "") in new stack
-- Executing [9001@T5_cos-all-post:2] NoOp("PJSIP/T5_51001-0000003c", "Custom Application: test") in new stack
-- Executing [9001@T5_cos-all-post:3] Goto("PJSIP/T5_51001-0000003c", "custom-contexts,cc-7,1") in new stack
-- Goto (custom-contexts,cc-7,1)
[2021-11-19 02:06:23] WARNING[9765][C-0000002a]: pbx.c:4510 __ast_pbx_run: Channel 'PJSIP/T5_51001-0000003c' sent to invalid extension but no invalid handler: context,exten,priority=custom-contexts,cc-7,1
