WebRTC behind firewall (SQUID Reverse Proxy / Sophos UTM Help)
Hi @maynor,
Yes:
See pastebin link: https://pastebin.com/6BsPsiVu or the raw version: https://pastebin.com/raw/6BsPsiVu
Let me know if you need any further information
Hi Sir!
I see that you can access port 8089, which means that the pjsip websocket is working fine. The issue you have in VitXi is that you have no audio?
If so, you can verify in the “RTP Settings” module, that Ice Support is enabled and Strict RTP is disabled.
I look forward to your comments,
Hi @maynor
Audio is working fine.
We are getting every few minutes a red pop up with message :
And calls randomly get disconnected.
Hello. Friendly follow up…
Hello sir.
We would like to review the problem in detail, could you please send us your AnyDesk ID to [email protected]?
Regards!,
