After updating to Version 4 (then updating today to the latest update) I find that the voicemail hints - of the form “vm_xxxx” where"xxxx" is the extension number - are no longer working.
A message is in Voicemail Box 2442, yet the device lamps do not indicate it. So I executed the command CORE SHOT HIMT vm_2442 and the following showed on the console:
mercury66*CLI> core show hint vm_2442
vm_2442@extension-hi: MWI:2442@vitalpbx-vo State:InUse Presence:not_set Watchers 3
1 hint matching extension vm_2442
Has something changed? Previously in VitalPBX 3, the hints would work, and the lamps on the phone set to monitor the hints would light.
