VitXi 4.0.4-2 websockets error on get_calls
VitXi on Android and Windows 11 works well; using it for outbound only.
VitalPBX 4.1.0-1 on arm64 (latest vs -5 on amd64 ?), PBX Engine 18.16.0, kernel 5.10.0-30.
Since (or around) the last Let’s encrypt certificate renewal the call history doesn’t work anymore. The throbber spins for a couple of minutes and then it briefly shows: “Error: websocket request timed out for event get_calls”.
Note that everything else is functional.
I tried (to no avail):
vitalpbx apply-firewall
/usr/share/vitxi/backend/artisan websockets:ssl-config
systemctl restart vitxi
and /usr/share/vitxi/backend/.env looks alright to me.
Any suggestions?
Screenshot 2024-06-22 155912
This issue was resolved by upgrading VitalPBX to v.4.1.0-6 and VitXI to v. 4.1.0-0.
Perfect. If you have any other problems, feel free to open a new topic.
