Klemen
September 14, 2022, 10:16am
#1
I am using the VitalPBX Phone provisioning module, specifically for Fanvil X4 devices.
When provisioning a device that is using a template and enabling the “Overwrite template” option on a DSS key, the overwrite does not occur after reprovisioning the device.
Can someone please help with this issue?
Thanks and Best regards, Klemen
Roger
September 16, 2022, 6:10pm
#2
Thank you for reporting the issue
We’ll analyse it and keep you updated
Roger
September 19, 2022, 3:21pm
#3
Please go to the template section and on the custom tab replace the following
@foreach($sideKeys as $key)
SoftFkey{{ $loop->iteration }} Type :{{ $key['type'] ?? null }}
SoftFkey{{ $loop->iteration }} Value :{{ $key['value'] ?? null }}
SoftFkey{{ $loop->iteration }} Title :{{ $key['title'] ?? null }}
@endforeach
@foreach(array_chunk($dssKeys, 6) as $chunk)
--Dsskey Config{{ $loop->iteration }}--:
@foreach($chunk as $key)
Fkey{{ $loop->iteration }} ICON :{{ $key['icon'] ?? 'Green' }}
@endforeach
@endforeach
mo10
September 20, 2022, 10:18am
#4
@Klemen will you test an report back? Thanks
system
Closed
October 20, 2022, 10:18am
#5
