VitalPBX 4: Issue while saving data after Branding modification
Hello dear team
We are facing issue on V4 while trying to modify the Branding section!
Can you please assist?
Best regards
Which version of VitalPBX?
Try
vitalpbx check-integrity
Hello dear
Thanks for your feedback
The result of tha command gave :
No Issues found
Gmap,
I believe I ran into this same situation. Although not always practical, have you tried restarting the server?
Thanks,
Fernando
hello dear @ferher1
Let me try
ÉDIT:
I restarted the server but no chance, same issue
Best regards
Gmap,
Just to make sure, you have a licensed version of VitalPBX 4? I know that some of the branding takes effect with a license while some of the branding doesn’t need a license.
Looks like this is only an issue for multi tenant.
Yes, we have a Career Plus licence!
Are you running the latest VitalPBX 4?
Are you applying the branding settings from the main tenant? Remember that branding add-on it’s not multi-tenant.
Hello dear @miguel
We are running Version 4.0.1 and we are connected as Admin on Main Tenant
And bellow is what we are exactly trying to change
When we click on SAVE
Check the folder permissions of your installation. I’ve tried in a brand new installation, and I had no issues.
@miguel sure
Which permissions should we give? 777 ?
You should never give permission 777 to a public folder.
According to the installation file of the branding add-on, applying these commands should be enough
chown www-data:www-data /usr/share/vitalpbx/www/resources/css/branding
chown -R www-data:www-data /usr/share/vitalpbx/www/resources/css/branding
Hello dear @miguel
Thanks a lot as this solved the issue
Best regards
