Seems like Vitalpbx4 repo is missing.
Failed to fetch https://repo.vitalpbx.com/vitalpbx/v4/apt/base/dists/stable/InRelease Unable to connect to repo.vitalpbx.com:https:
Indeed, looks like it is down.
We are having issues with your current data center. So, we’re trying to migrate to a new one.
The VitalPBX 4 repo is online again.
It is possible that you have to reinstall the repo again. You can use the command below; this is to update GPG Key.
curl -fsSL https://repo.vitalpbx.com/vitalpbx/v4/apt/setup_repo | bash -
