Hi
im trying to install / configure Sonata Stat but at the wizard where he is trying to establish PBX link it giving me following error
Connection could not be established, please check the data entered.
http is allowed in firewall but not sure where is the issue
check the screen shot please
Hi!
It seems that the screenshot is not uploaded, could you please check?
Hello Maynor
i managed to fix to it
i’m using custom http port and therefore once i change the port from 80 to custom port it worked
Perfect Sir!
If you have any other problems, do not hesitate to open another topic.
Regards!
