Here’s the inbound call info, I checked and read every single line, to no avail:
root@vitalpbx01:/var/log/asterisk# cat full | grep C-00000264
[+1CALLEDNMBR@trk-1-in:1] NoOp(“PJSIP/SBC_trunk-00000500”, “Incoming call through: SBC_trunk”) in new stack
[+1CALLEDNMBR@trk-1-in:2] Set(“PJSIP/SBC_trunk-00000500”, “__TRUNK_ID=1”) in new stack
[+1CALLEDNMBR@trk-1-in:3] Set(“PJSIP/SBC_trunk-00000500”, “CDR(trunk)=1”) in new stack
[+1CALLEDNMBR@trk-1-in:4] Set(“PJSIP/SBC_trunk-00000500”, “__DID_NUMBER=+1CALLEDNMBR”) in new stack
[+1CALLEDNMBR@trk-1-in:5] Set(“PJSIP/SBC_trunk-00000500”, “CDR(did)=+1CALLEDNMBR”) in new stack
[+1CALLEDNMBR@trk-1-in:6] Set(“PJSIP/SBC_trunk-00000500”, “DID=+1CALLEDNMBR”) in new stack
[+1CALLEDNMBR@trk-1-in:7] Goto(“PJSIP/SBC_trunk-00000500”, “default-trunk,+1CALLEDNMBR,1”) in new stack
pbx_builtins.c: Goto (default-trunk,+1CALLEDNMBR,1)
[+1CALLEDNMBR@default-trunk:1] Gosub(“PJSIP/SBC_trunk-00000500”, “set-global-tenant-vars,s,1”) in new stack
[s@set-global-tenant-vars:1] NoOp(“PJSIP/SBC_trunk-00000500”, “Setting Global Vars for vitalpbx Tenant”) in new stack
[s@set-global-tenant-vars:2] Set(“PJSIP/SBC_trunk-00000500”, “__TENANT_PATH=268f0bb96e2f8df5”) in new stack
[s@set-global-tenant-vars:3] Set(“PJSIP/SBC_trunk-00000500”, “__TENANT_PREFIX=”) in new stack
[s@set-global-tenant-vars:4] Set(“PJSIP/SBC_trunk-00000500”, “__QUEUE_AGENTS_CONTEXT=queue-call-to-agents”) in new stack
[s@set-global-tenant-vars:5] Set(“PJSIP/SBC_trunk-00000500”, “__FOLLOWME_CONTEXT=ext-followme”) in new stack
[s@set-global-tenant-vars:6] Set(“PJSIP/SBC_trunk-00000500”, “__HINTS_CONTEXT=extension-hints”) in new stack
[s@set-global-tenant-vars:7] Set(“PJSIP/SBC_trunk-00000500”, “__DEFAULT_COS=cos-all”) in new stack
[s@set-global-tenant-vars:8] Return(“PJSIP/SBC_trunk-00000500”, “”) in new stack
[+1CALLEDNMBR@default-trunk:2] Gosub(“PJSIP/SBC_trunk-00000500”, “sub-check-blacklist,s,1(268f0bb96e2f8df5,+1CALLINGNMBR)”) in new stack
[s@sub-check-blacklist:1] NoOp(“PJSIP/SBC_trunk-00000500”, “Testing if +1CALLINGNMBR is in Black List”) in new stack
[s@sub-check-blacklist:2] GotoIf(“PJSIP/SBC_trunk-00000500”, “0?banned”) in new stack
[s@sub-check-blacklist:3] Return(“PJSIP/SBC_trunk-00000500”, “”) in new stack
[+1CALLEDNMBR@default-trunk:3] Gosub(“PJSIP/SBC_trunk-00000500”, “sub-stir-shaken-verify,s,1(268f0bb96e2f8df5,+1CALLINGNMBR)”) in new stack
[s@sub-stir-shaken-verify:1] NoOp(“PJSIP/SBC_trunk-00000500”, “STIR Shaken Verify”) in new stack
[s@sub-stir-shaken-verify:2] Set(“PJSIP/SBC_trunk-00000500”, “STIR_SHAKEN_IDENTITIES=0”) in new stack
[s@sub-stir-shaken-verify:3] NoOp(“PJSIP/SBC_trunk-00000500”, “Number of STIR/SHAKEN identities: 0”) in new stack
[s@sub-stir-shaken-verify:4] GotoIf(“PJSIP/SBC_trunk-00000500”, “1?end”) in new stack
pbx_builtins.c: Goto (sub-stir-shaken-verify,s,6)
[s@sub-stir-shaken-verify:6] Return(“PJSIP/SBC_trunk-00000500”, “”) in new stack
[+1CALLEDNMBR@default-trunk:4] Gosub(“PJSIP/SBC_trunk-00000500”, “sub-setup-call-type,s,1(incoming)”) in new stack
[s@sub-setup-call-type:1] NoOp(“PJSIP/SBC_trunk-00000500”, “Determinating Call Type”) in new stack
[s@sub-setup-call-type:2] GotoIf(“PJSIP/SBC_trunk-00000500”, “0?return”) in new stack
[s@sub-setup-call-type:3] Gosub(“PJSIP/SBC_trunk-00000500”, “s-incoming,1()”) in new stack
[s-incoming@sub-setup-call-type:1] NoOp(“PJSIP/SBC_trunk-00000500”, “Incoming Call”) in new stack
[s-incoming@sub-setup-call-type:2] Set(“PJSIP/SBC_trunk-00000500”, “__CALL_TYPE=2”) in new stack
[s-incoming@sub-setup-call-type:3] Set(“PJSIP/SBC_trunk-00000500”, “__CALL_TYPE_LABEL=IN”) in new stack
[s-incoming@sub-setup-call-type:4] Return(“PJSIP/SBC_trunk-00000500”, “”) in new stack
[s@sub-setup-call-type:4] Set(“PJSIP/SBC_trunk-00000500”, “__CALL_TYPE_CONFIGURED=yes”) in new stack
[s@sub-setup-call-type:5] Set(“PJSIP/SBC_trunk-00000500”, “CDR(calltype)=2”) in new stack
[s@sub-setup-call-type:6] Return(“PJSIP/SBC_trunk-00000500”, “”) in new stack
[+1CALLEDNMBR@default-trunk:5] Gosub(“PJSIP/SBC_trunk-00000500”, “dynamic-routing-in,s,1(+1CALLINGNMBR)”) in new stack
[s@dynamic-routing-in:1] NoOp(“PJSIP/SBC_trunk-00000500”, “Test if must to apply dynamic routing”) in new stack
[s@dynamic-routing-in:2] Set(“PJSIP/SBC_trunk-00000500”, “EXTERNAL_CALLER=+1CALLINGNMBR”) in new stack
[s@dynamic-routing-in:3] Set(“PJSIP/SBC_trunk-00000500”, “DYNROUTING_DM=0”) in new stack
[s@dynamic-routing-in:4] GotoIf(“PJSIP/SBC_trunk-00000500”, “1?gd”) in new stack
pbx_builtins.c: Goto (dynamic-routing-in,s,6)
[s@dynamic-routing-in:6] GotoIf(“PJSIP/SBC_trunk-00000500”, “0?:rb”) in new stack
pbx_builtins.c: Goto (dynamic-routing-in,s,11)
[s@dynamic-routing-in:11] Return(“PJSIP/SBC_trunk-00000500”, “”) in new stack
[+1CALLEDNMBR@default-trunk:6] ExecIf(“PJSIP/SBC_trunk-00000500”, “0?Set(__DID_NUMBER=+1CALLEDNMBR):”) in new stack
[+1CALLEDNMBR@default-trunk:7] Goto(“PJSIP/SBC_trunk-00000500”, “incoming-calls,+1CALLEDNMBR,1”) in new stack
pbx_builtins.c: Goto (incoming-calls,+1CALLEDNMBR,1)
[+1CALLEDNMBR@incoming-calls:1] NoOp(“PJSIP/SBC_trunk-00000500”, “INBOUND_ROUTE: Affiliates”) in new stack
[+1CALLEDNMBR@incoming-calls:2] Set(“PJSIP/SBC_trunk-00000500”, “CHANNEL(language)=en”) in new stack
[+1CALLEDNMBR@incoming-calls:3] Set(“PJSIP/SBC_trunk-00000500”, “__INBOUND_LANGUAGE=en”) in new stack
[+1CALLEDNMBR@incoming-calls:4] Gosub(“PJSIP/SBC_trunk-00000500”, “sub-set-moh,s,1(default,YES)”) in new stack
[s@sub-set-moh:1] NoOp(“PJSIP/SBC_trunk-00000500”, “Configuring MoH Class”) in new stack
[s@sub-set-moh:2] Set(“PJSIP/SBC_trunk-00000500”, “MOH_CLASS=default”) in new stack
[s@sub-set-moh:3] Set(“PJSIP/SBC_trunk-00000500”, “MOH_FORCE=YES”) in new stack
[s@sub-set-moh:4] GotoIf(“PJSIP/SBC_trunk-00000500”, “0?end”) in new stack
[s@sub-set-moh:5] GotoIf(“PJSIP/SBC_trunk-00000500”, “1?:end”) in new stack
[s@sub-set-moh:6] Set(“PJSIP/SBC_trunk-00000500”, “CHANNEL(musicclass)=default”) in new stack
[s@sub-set-moh:7] Set(“PJSIP/SBC_trunk-00000500”, “__MOH_SET=YES”) in new stack
[s@sub-set-moh:8] Return(“PJSIP/SBC_trunk-00000500”, “”) in new stack
[+1CALLEDNMBR@incoming-calls:5] Gosub(“PJSIP/SBC_trunk-00000500”, “sub-set-call-vars,s-incoming,1(+1CALLINGNMBR,+1CALLEDNMBR,268f0bb96e2f8df5)”) in new stack
[s-incoming@sub-set-call-vars:1] NoOp(“PJSIP/SBC_trunk-00000500”, “Setting Incoming Call Vars”) in new stack
[s-incoming@sub-set-call-vars:2] Set(“PJSIP/SBC_trunk-00000500”, “__CALLID=1686681382.1432”) in new stack
[s-incoming@sub-set-call-vars:3] Set(“PJSIP/SBC_trunk-00000500”, “__INCOMING_SOURCE=+1CALLINGNMBR”) in new stack
[s-incoming@sub-set-call-vars:4] Set(“PJSIP/SBC_trunk-00000500”, “__INCOMING_DESTINATION=+1CALLEDNMBR”) in new stack
[s-incoming@sub-set-call-vars:5] Set(“PJSIP/SBC_trunk-00000500”, “__INCOMING_TENANT=268f0bb96e2f8df5”) in new stack
[s-incoming@sub-set-call-vars:6] Set(“PJSIP/SBC_trunk-00000500”, “__CALL_SOURCE=+1CALLINGNMBR”) in new stack
[s-incoming@sub-set-call-vars:7] Set(“PJSIP/SBC_trunk-00000500”, “__CS=+1CALLINGNMBR”) in new stack
[s-incoming@sub-set-call-vars:8] Set(“PJSIP/SBC_trunk-00000500”, “__CALL_DESTINATION=+1CALLEDNMBR”) in new stack
[s-incoming@sub-set-call-vars:9] Set(“PJSIP/SBC_trunk-00000500”, “__TENANT=268f0bb96e2f8df5”) in new stack
[s-incoming@sub-set-call-vars:10] Set(“PJSIP/SBC_trunk-00000500”, “CDR(tenant)=vitalpbx”) in new stack
[s-incoming@sub-set-call-vars:11] Set(“PJSIP/SBC_trunk-00000500”, “CDR(destination)=+1CALLEDNMBR”) in new stack
[s-incoming@sub-set-call-vars:12] Set(“PJSIP/SBC_trunk-00000500”, “CDR(trunk)=1”) in new stack
[s-incoming@sub-set-call-vars:13] Set(“PJSIP/SBC_trunk-00000500”, “CDR(did)=+1CALLEDNMBR”) in new stack
[s-incoming@sub-set-call-vars:14] Set(“PJSIP/SBC_trunk-00000500”, “CDR(calltype)=2”) in new stack
[s-incoming@sub-set-call-vars:15] ExecIf(“PJSIP/SBC_trunk-00000500”, “1?Set(__PJSIP_CALLID=02169D1679814000003667F4@VOICEVLAN_TS)”) in new stack
[s-incoming@sub-set-call-vars:16] Gosub(“PJSIP/SBC_trunk-00000500”, “app-incoming,1”) in new stack
[app-incoming@sub-set-call-vars:1] NoOp(“PJSIP/SBC_trunk-00000500”, “Incoming Call App CDR”) in new stack
[app-incoming@sub-set-call-vars:2] GotoIf(“PJSIP/SBC_trunk-00000500”, “1?:return”) in new stack
[app-incoming@sub-set-call-vars:3] Set(“PJSIP/SBC_trunk-00000500”, “CDR(source)=+1CALLINGNMBR”) in new stack
[app-incoming@sub-set-call-vars:4] Set(“PJSIP/SBC_trunk-00000500”, “CDR(tenant)=vitalpbx”) in new stack
[app-incoming@sub-set-call-vars:5] Set(“PJSIP/SBC_trunk-00000500”, “CDR(destination)=+1CALLEDNMBR”) in new stack
[app-incoming@sub-set-call-vars:6] Return(“PJSIP/SBC_trunk-00000500”, “”) in new stack
[s-incoming@sub-set-call-vars:17] Return(“PJSIP/SBC_trunk-00000500”, “”) in new stack
[+1CALLEDNMBR@incoming-calls:6] Set(“PJSIP/SBC_trunk-00000500”, “ICALL=yes”) in new stack
[+1CALLEDNMBR@incoming-calls:7] Goto(“PJSIP/SBC_trunk-00000500”, “ext-queues,100,1”) in new stack
pbx_builtins.c: Goto (ext-queues,100,1)
[100@ext-queues:1] NoOp(“PJSIP/SBC_trunk-00000500”, “Queue: 100 Customer Service”) in new stack
[100@ext-queues:2] Set(“PJSIP/SBC_trunk-00000500”, “__QUEUE_UID=1686681382.1432”) in new stack
[100@ext-queues:3] Set(“PJSIP/SBC_trunk-00000500”, “__QUEUE_CALL=TRUE”) in new stack
[100@ext-queues:4] Set(“PJSIP/SBC_trunk-00000500”, “__SKIP_AA=TRUE”) in new stack
[100@ext-queues:5] Set(“PJSIP/SBC_trunk-00000500”, “__FROM_QUEUE_ID=3”) in new stack
[100@ext-queues:6] Gosub(“PJSIP/SBC_trunk-00000500”, “sub-set-moh,s,1(default,YES)”) in new stack
[100@ext-queues:7] Set(“PJSIP/SBC_trunk-00000500”, “__QUEUE_NUMBER=100”) in new stack
[100@ext-queues:8] Set(“PJSIP/SBC_trunk-00000500”, “__QUEUE_NAME=Q100”) in new stack
[100@ext-queues:9] Set(“PJSIP/SBC_trunk-00000500”, “__PBX_APP=QUEUE”) in new stack
[100@ext-queues:10] Set(“PJSIP/SBC_trunk-00000500”, “__PBX_APP_DESC=100 Customer Service”) in new stack
[100@ext-queues:11] Gosub(“PJSIP/SBC_trunk-00000500”, “sub-set-call-vars,app-incoming,1”) in new stack
[100@ext-queues:12] Set(“PJSIP/SBC_trunk-00000500”, “_APP_RECORDING=yes”) in new stack
[100@ext-queues:13] NoOp(“PJSIP/SBC_trunk-00000500”, “Connecting to Queue”) in new stack
[100@ext-queues:14] Set(“PJSIP/SBC_trunk-00000500”, “ANSWER_CHANNEL=yes”) in new stack
[100@ext-queues:15] ExecIf(“PJSIP/SBC_trunk-00000500”, “0?Progress():Answer()”) in new stack
[100@ext-queues:16] NoCDR(“PJSIP/SBC_trunk-00000500”, “”) in new stack
[100@ext-queues:17] Set(“PJSIP/SBC_trunk-00000500”, “Q_RING_TIME=”) in new stack
[100@ext-queues:18] ExecIf(“PJSIP/SBC_trunk-00000500”, “0?Set(Q_RING_TIME=):”) in new stack
[100@ext-queues:19] Queue(“PJSIP/SBC_trunk-00000500”, “Q100,”) in new stack
res_musiconhold.c: Started music on hold, class ‘default’, on channel ‘PJSIP/SBC_trunk-00000500’
app_queue.c: Called PJSIP/1058
app_queue.c: PJSIP/1058-00000501 is ringing
app_queue.c: PJSIP/1058-00000501 answered PJSIP/SBC_trunk-00000500
res_musiconhold.c: Stopped music on hold on PJSIP/SBC_trunk-00000500
bridge_channel.c: Channel PJSIP/1058-00000501 joined ‘simple_bridge’ basic-bridge
bridge_channel.c: Channel PJSIP/SBC_trunk-00000500 joined ‘simple_bridge’ basic-bridge
bridge_channel.c: Channel PJSIP/1058-00000501 left ‘simple_bridge’ basic-bridge
bridge_channel.c: Channel PJSIP/SBC_trunk-00000500 left ‘simple_bridge’ basic-bridge
pbx.c: Spawn extension (ext-queues, 100, 19) exited non-zero on ‘PJSIP/SBC_trunk-00000500’
pbx.c: Executing [h@ext-queues:1] NoOp(“PJSIP/SBC_trunk-00000500”, “Ending Queue Call”) in new stack
pbx.c: Executing [h@ext-queues:2] Hangup(“PJSIP/SBC_trunk-00000500”, “”) in new stack
pbx.c: Spawn extension (ext-queues, h, 2) exited non-zero on ‘PJSIP/SBC_trunk-00000500’
I see the NoCDR although the all was answered and I was able to speak to the agent, so that makes even less sense.
Could it be some sort of bug in queue creation? could it be that something went wrong when importing the extensions?
regards,
