Gkerna
February 10, 2023, 6:15pm
#1
hi
im using a kamailio proxy and its dispatcher module to send sip to back end asterisk servers .
but im getting the error below on a VitalPBX ver 4 server , ive enabled “support Path” Default PJSIP Profile
VitalPBX Ver 3 running SIP for endpoints is working OK
res_pjsip_registrar.c:712 register_aor_core: Invalid modifications made to REGISTER request from ‘101’ by intervening proxy
what would this error indicate ?
gerry
PitzKey
February 11, 2023, 5:25pm
#2
Can you please share the original and modified REGISTER request?
Gkerna
February 12, 2023, 1:49pm
#3
hi
register from endpoint
2023/02/12 13:40:12.040634 X.X.X:57151 → 10.3.1.6:5060
REGISTER sip:sip.vvr.ie:5060 SIP/2.0
Via: SIP/2.0/UDP 37…X:57151;branch=z9hG4bK-d8754z-0724c04b1100e934-1—d8754z-;rport
Max-Forwards: 70
Contact: sip:101@37...:57151;rinstance=11da62238434574b
To: "101"sip:101@sip.vvr.ie:5060
Call-ID: NTk0MGViZjQ5MjhmNTYwYmRjMzA2ZTFlNGY4YjU1ZmY.
CSeq: 1 REGISTER
Expires: 120
Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REGISTER, SUBSCRIBE, NOTIFY, REFER, INFO, MESSAGE
Supported: replaces
User-Agent: 3CXPhone 6.0.26523.0
Content-Length: 0
register from Kamilio proxy 10.3.1.6 to Asterisk10.3.1.8
2023/02/12 13:45:31.462763 10.3.1.6:5060 → 10.3.1.8:5060
Via: SIP/2.0/UDP Y.Y.Y.Y:5060;branch=z9hG4bKcd84.a58141c6ca925a6a4c9f059d74661a5c.0
Via: SIP/2.0/UDP 3X.X.X.X:54500;received=3X.X.X.X;branch=z9hG4bK-d8754z-0643b801975eda00-1—d8754z-;rport=54500
Max-Forwards: 69
Contact: sip:101@3X.X.X.X:54500;rinstance=aa8d8d1879639087
Call-ID: ODY5OGE1ZjY2MzZiNTQ1ODc5YzViYWNjOTBiNTIyOGU.
CSeq: 1 REGISTER
Expires: 120
Supported: replaces
Content-Length: 0
Path: sip:Y.Y.Y.Y:5060;lr;received=sip:3X.X.X.X:54500
2023/02/12 13:38:01.430381 10.3.1.8:5060 → 10.3.1.6:5060
SIP/2.0 401 Unauthorized
Via: SIP/2.0/UDP Y.Y.Y.Y:5060;rport=5060;received=10.3.1.6;branch=z9hG4bK1e3b.edf32e5147f1fccd0bc425a4aca28816.0
Via: SIP/2.0/UDP X.X.X.X:63451;rport=63451;received=X.X.X.X;branch=z9hG4bK-d8754z-6550333fe0377c1d-1—d8754z-
Call-ID: ZWFjOTBmM2JmZWMxMGQ5ZWE4ODM2MzMzMzAxOTdiN2M.
To: “101” sip:101@sip.vvr.ie ;tag=z9hG4bK1e3b.edf32e5147f1fccd0bc425a4aca28816.0
CSeq: 1 REGISTER
WWW-Authenticate: Digest realm=“asterisk”,nonce=“1676209081/ef53b310d5054dc362d15df7c7dcf268”,opaque=“4a2e060f6ac154fd”,algorithm=MD5,qop=“auth”
Server: VitalPBX
Content-Length: 0
2023/02/12 13:38:01.572441 10.3.1.8:5060 → 10.3.1.6:5060
SIP/2.0 420 Bad Extension
Via: SIP/2.0/UDP Y.Y.Y.Y:5060;rport=5060;received=10.3.1.6;branch=z9hG4bKed3b.a8d593f0bb829a933b4a20e2ed3f6ab1.0
Via: SIP/2.0/UDP X.X.X.X.X:63451;rport=63451;received=37.228.198.59;branch=z9hG4bK-d8754z-9407ac1803016563-1—d8754z-
To: “101” sip:101@sip.vvr.ie ;tag=z9hG4bKed3b.a8d593f0bb829a933b4a20e2ed3f6ab1.0
CSeq: 2 REGISTER
Server: VitalPBX
Content-Length: 0
system
Closed
March 14, 2023, 1:50pm
#4
