At the bottom of the modules__20-noload.conf file it states that you shouldn’t edit the file.
It appears that explicitly marking a module with noload will prevent it from loading - even when a subsequent or prior load command exists.
For the time being I’m just commenting out those lines, but naturally my concern is that this file may be overwritten in the future.
This appears to have also been brought up before:
https://community.vitalpbx.org/forums/topic/auto-activating-res_snmp/
Would it not make more sense to leave autoload off and only explicitly load whatever modules are needed for VitalPBX, and then do away with the modules__20-noload.conf file all together?
Thanks,
Bryan
