it will be a good feature to be able to set account code on each tenant trunk separately
{ X-Tenant header } on the outbound trunks
When I’m using an external billing system
It doesn’t work when you set this on the parent Trunk?
Yes but I will have to create a parent truck for each tenant
now I’m I have one parent trunk and each tenant is using the same parent trunk
just a different tenant trunk
Exactly, you use only one parent Trunk and you add the X-Tenant header there and use a variable as the value.
If I’m doing like this I’m getting a random account code set by VitalPBX
I would like to set my own account codes as I used to do on my old server
I like to keep my billing system neat with the account codes I create
is there a way I can create my own account code or change them
This is the tenant ID, which is usually not changed.
2 things you can try.
${DB(${TENANT_PATH}/myaccountcode)}
