This only issue is now that when I call from Ext 3000019 → Ext 333, the ${CALLERID(num)} is not returning anything, I use this aestrix variable for conditions in my script, any idea ?
If I remove the [before-bridging-call-hook] then ${CALLERID(num)} returns 3000019
Connected to Asterisk 18.10.0 currently running on phone (pid = 1376)
-- Executing [333@cos-all:1] NoOp("PJSIP/3000019-000001a0", "More than on digit pattern") in new stack
-- Executing [333@cos-all:2] Gosub("PJSIP/3000019-000001a0", "s,1(333)") in new stack
-- Executing [s@cos-all:1] Set("PJSIP/3000019-000001a0", "EXTENSION=333") in new stack
-- Executing [s@cos-all:2] NoOp("PJSIP/3000019-000001a0", "Dialing 333 from 3000019") in new stack
-- Executing [s@cos-all:3] Gosub("PJSIP/3000019-000001a0", "sub-set-global-vars,s,1(6787bde866811108,333,parking-1)") in new stack
-- Executing [s@sub-set-global-vars:1] NoOp("PJSIP/3000019-000001a0", "Setting Global Vars") in new stack
-- Executing [s@sub-set-global-vars:2] Set("PJSIP/3000019-000001a0", "TENANT_PATH=6787bde866811108") in new stack
-- Executing [s@sub-set-global-vars:3] Set("PJSIP/3000019-000001a0", "PREFIX=") in new stack
-- Executing [s@sub-set-global-vars:4] Set("PJSIP/3000019-000001a0", "__PICKUPMARK=333") in new stack
-- Executing [s@sub-set-global-vars:5] Set("PJSIP/3000019-000001a0", "__PARKINGLOT=parking-1") in new stack
-- Executing [s@sub-set-global-vars:6] Set("PJSIP/3000019-000001a0", "__DYNAMIC_FEATURES=custom-features") in new stack
-- Executing [s@sub-set-global-vars:7] Set("PJSIP/3000019-000001a0", "ICALL=no") in new stack
-- Executing [s@sub-set-global-vars:8] Return("PJSIP/3000019-000001a0", "") in new stack
-- Executing [s@cos-all:4] Gosub("PJSIP/3000019-000001a0", "sub-set-call-vars,s,1(6787bde866811108,333,1,cos-all,ARS-all)") in new stack
-- Executing [s@sub-set-call-vars:1] NoOp("PJSIP/3000019-000001a0", "Setting Call Vars") in new stack
-- Executing [s@sub-set-call-vars:2] Set("PJSIP/3000019-000001a0", "_TENANT=6787bde866811108") in new stack
-- Executing [s@sub-set-call-vars:3] Set("PJSIP/3000019-000001a0", "_CALL_DESTINATION=333") in new stack
-- Executing [s@sub-set-call-vars:4] Set("PJSIP/3000019-000001a0", "_COS_ID=1") in new stack
-- Executing [s@sub-set-call-vars:5] Set("PJSIP/3000019-000001a0", "_COS_NAME=cos-all") in new stack
-- Executing [s@sub-set-call-vars:6] Set("PJSIP/3000019-000001a0", "__TRANSFER_CONTEXT=cos-all") in new stack
-- Executing [s@sub-set-call-vars:7] Set("PJSIP/3000019-000001a0", "_ARS=ARS-all") in new stack
-- Executing [s@sub-set-call-vars:8] Set("PJSIP/3000019-000001a0", "CDR(tenant)=vitalpbx") in new stack
-- Executing [s@sub-set-call-vars:9] Set("PJSIP/3000019-000001a0", "CDR(destination)=333") in new stack
-- Executing [s@sub-set-call-vars:10] Set("PJSIP/3000019-000001a0", "CDR(trunk)=") in new stack
-- Executing [s@sub-set-call-vars:11] Set("PJSIP/3000019-000001a0", "CDR(did)=") in new stack
-- Executing [s@sub-set-call-vars:12] Set("PJSIP/3000019-000001a0", "__CALLID=1662005851.1820") in new stack
-- Executing [s@sub-set-call-vars:13] ExecIf("PJSIP/3000019-000001a0", "0?Set(CHANNEL(language)=)") in new stack
-- Executing [s@sub-set-call-vars:14] ExecIf("PJSIP/3000019-000001a0", "0?Set(CHANNEL(language)=)") in new stack
-- Executing [s@sub-set-call-vars:15] Return("PJSIP/3000019-000001a0", "") in new stack
-- Executing [s@cos-all:5] Gosub("PJSIP/3000019-000001a0", "sub-construct-cid,s,1") in new stack
-- Executing [s@sub-construct-cid:1] NoOp("PJSIP/3000019-000001a0", "Building CID") in new stack
-- Executing [s@sub-construct-cid:2] Set("PJSIP/3000019-000001a0", "_CALL_SOURCE=3000019") in new stack
-- Executing [s@sub-construct-cid:3] Set("PJSIP/3000019-000001a0", "_CS=3000019") in new stack
-- Executing [s@sub-construct-cid:4] GotoIf("PJSIP/3000019-000001a0", "0?return") in new stack
-- Executing [s@sub-construct-cid:5] Gosub("PJSIP/3000019-000001a0", "sub-get-device-tree,s,1") in new stack
-- Executing [s@sub-get-device-tree:1] NoOp("PJSIP/3000019-000001a0", "Configuring Device Tree") in new stack
-- Executing [s@sub-get-device-tree:2] Set("PJSIP/3000019-000001a0", "DEV_TECHNOLOGY=PJSIP") in new stack
-- Executing [s@sub-get-device-tree:3] GosubIf("PJSIP/3000019-000001a0", "0?s-local,1") in new stack
-- Executing [s@sub-get-device-tree:4] GotoIf("PJSIP/3000019-000001a0", "0?return") in new stack
-- Executing [s@sub-get-device-tree:5] GotoIf("PJSIP/3000019-000001a0", "1?pjsip") in new stack
-- Goto (sub-get-device-tree,s,9)
-- Executing [s@sub-get-device-tree:9] NoOp("PJSIP/3000019-000001a0", "A PJSIP") in new stack
-- Executing [s@sub-get-device-tree:10] Set("PJSIP/3000019-000001a0", "DEV_USER=3000019") in new stack
-- Executing [s@sub-get-device-tree:11] Goto("PJSIP/3000019-000001a0", "build_interface") in new stack
-- Goto (sub-get-device-tree,s,13)
-- Executing [s@sub-get-device-tree:13] Set("PJSIP/3000019-000001a0", "_INTERFACE=PJSIP/3000019") in new stack
-- Executing [s@sub-get-device-tree:14] Set("PJSIP/3000019-000001a0", "DEV_TREE=devices/PJSIP/3000019") in new stack
-- Executing [s@sub-get-device-tree:15] Return("PJSIP/3000019-000001a0", "") in new stack
-- Executing [s@sub-construct-cid:6] GotoIf("PJSIP/3000019-000001a0", "0?return") in new stack
-- Executing [s@sub-construct-cid:7] Set("PJSIP/3000019-000001a0", "_CALL_SOURCE=3000019") in new stack
-- Executing [s@sub-construct-cid:8] Set("PJSIP/3000019-000001a0", "_CS=3000019") in new stack
-- Executing [s@sub-construct-cid:9] ExecIf("PJSIP/3000019-000001a0", "1?Set(CALLERID(all)="3000019" <3000019>)") in new stack
-- Executing [s@sub-construct-cid:10] Set("PJSIP/3000019-000001a0", "_CID_CONSTRUCTED=yes") in new stack
-- Executing [s@sub-construct-cid:11] NoOp("PJSIP/3000019-000001a0", "") in new stack
-- Executing [s@sub-construct-cid:12] Set("PJSIP/3000019-000001a0", "CDR(source)=3000019") in new stack
-- Executing [s@sub-construct-cid:13] Return("PJSIP/3000019-000001a0", "") in new stack
-- Executing [s@cos-all:6] Gosub("PJSIP/3000019-000001a0", "set-global-tenant-vars,s,1") in new stack
-- Executing [s@set-global-tenant-vars:1] NoOp("PJSIP/3000019-000001a0", "Setting Global Vars for vitalpbx Tenant") in new stack
-- Executing [s@set-global-tenant-vars:2] Set("PJSIP/3000019-000001a0", "__TENANT_PATH=6787bde866811108") in new stack
-- Executing [s@set-global-tenant-vars:3] Set("PJSIP/3000019-000001a0", "__TENANT_PREFIX=") in new stack
-- Executing [s@set-global-tenant-vars:4] Set("PJSIP/3000019-000001a0", "__QUEUE_AGENTS_CONTEXT=queue-call-to-agents") in new stack
-- Executing [s@set-global-tenant-vars:5] Set("PJSIP/3000019-000001a0", "__FOLLOWME_CONTEXT=ext-followme") in new stack
-- Executing [s@set-global-tenant-vars:6] Set("PJSIP/3000019-000001a0", "__HINTS_CONTEXT=extension-hints") in new stack
-- Executing [s@set-global-tenant-vars:7] Set("PJSIP/3000019-000001a0", "__DEFAULT_COS=cos-all") in new stack
-- Executing [s@set-global-tenant-vars:8] Return("PJSIP/3000019-000001a0", "") in new stack
-- Executing [s@cos-all:7] GotoIf("PJSIP/3000019-000001a0", "0?local-dialing") in new stack
-- Executing [s@cos-all:8] NoOp("PJSIP/3000019-000001a0", "Check if is an Emergency Call") in new stack
-- Executing [s@cos-all:9] GotoIf("PJSIP/3000019-000001a0", "0?emergency-calls,333,1") in new stack
-- Executing [s@cos-all:10] Gosub("PJSIP/3000019-000001a0", "sub-lockphone-check,s,1") in new stack
-- Executing [s@sub-lockphone-check:1] NoOp("PJSIP/3000019-000001a0", "SUB: LOCK PHONE CHECK") in new stack
-- Executing [s@sub-lockphone-check:2] GotoIf("PJSIP/3000019-000001a0", "0?unlock") in new stack
-- Executing [s@sub-lockphone-check:3] GotoIf("PJSIP/3000019-000001a0", "0?unlock") in new stack
-- Executing [s@sub-lockphone-check:4] GotoIf("PJSIP/3000019-000001a0", "0?unlock") in new stack
-- Executing [s@sub-lockphone-check:5] GotoIf("PJSIP/3000019-000001a0", "0?unlock") in new stack
-- Executing [s@sub-lockphone-check:6] GotoIf("PJSIP/3000019-000001a0", "0?:unlock") in new stack
-- Executing [s@sub-lockphone-check:12] Return("PJSIP/3000019-000001a0", "") in new stack
-- Executing [s@cos-all:11] Gosub("PJSIP/3000019-000001a0", "sub-local-dialing,s,1") in new stack
-- Executing [s@sub-local-dialing:1] NoOp("PJSIP/3000019-000001a0", "Trying to determine if is a local extension") in new stack
-- Executing [s@sub-local-dialing:2] GotoIf("PJSIP/3000019-000001a0", "1?:return") in new stack
-- Executing [s@sub-local-dialing:3] Set("PJSIP/3000019-000001a0", "EXTENSION_TO_DIAL=333") in new stack
-- Executing [s@sub-local-dialing:4] Goto("PJSIP/3000019-000001a0", "333,1") in new stack
-- Goto (sub-local-dialing,333,1)
-- Executing [333@sub-local-dialing:1] NoOp("PJSIP/3000019-000001a0", "Dialing Local Extension") in new stack
-- Executing [333@sub-local-dialing:2] ExecIf("PJSIP/3000019-000001a0", "0?NoCDR()") in new stack
-- Executing [333@sub-local-dialing:3] Gosub("PJSIP/3000019-000001a0", "sub-setup-call-type,s,1(internal)") in new stack
-- Executing [s@sub-setup-call-type:1] NoOp("PJSIP/3000019-000001a0", "Determinating Call Type") in new stack
-- Executing [s@sub-setup-call-type:2] GotoIf("PJSIP/3000019-000001a0", "0?return") in new stack
-- Executing [s@sub-setup-call-type:3] Gosub("PJSIP/3000019-000001a0", "s-internal,1()") in new stack
-- Executing [s-internal@sub-setup-call-type:1] NoOp("PJSIP/3000019-000001a0", "Internal Call") in new stack
-- Executing [s-internal@sub-setup-call-type:2] Set("PJSIP/3000019-000001a0", "__CALL_TYPE=1") in new stack
-- Executing [s-internal@sub-setup-call-type:3] Set("PJSIP/3000019-000001a0", "__CALL_TYPE_LABEL=LOCAL") in new stack
-- Executing [s-internal@sub-setup-call-type:4] Return("PJSIP/3000019-000001a0", "") in new stack
-- Executing [s@sub-setup-call-type:4] Set("PJSIP/3000019-000001a0", "__CALL_TYPE_CONFIGURED=yes") in new stack
-- Executing [s@sub-setup-call-type:5] Set("PJSIP/3000019-000001a0", "CDR(calltype)=1") in new stack
-- Executing [s@sub-setup-call-type:6] Return("PJSIP/3000019-000001a0", "") in new stack
-- Executing [333@sub-local-dialing:4] Set("PJSIP/3000019-000001a0", "_DESTINATION_STATE=NOT_INUSE") in new stack
-- Executing [333@sub-local-dialing:5] Set("PJSIP/3000019-000001a0", "_DESTINATION_NUMBER=333") in new stack
-- Executing [333@sub-local-dialing:6] Set("PJSIP/3000019-000001a0", "_DESTINATION_COS_NAME=cos-all") in new stack
-- Executing [333@sub-local-dialing:7] Gosub("PJSIP/3000019-000001a0", "sub-check-cos-privacy,s,1(cos-all,1,cos-all)") in new stack
-- Executing [s@sub-check-cos-privacy:1] NoOp("PJSIP/3000019-000001a0", "Checking Privacy of CoS: cos-all") in new stack
-- Executing [s@sub-check-cos-privacy:2] GotoIf("PJSIP/3000019-000001a0", "1?:no_local") in new stack
-- Executing [s@sub-check-cos-privacy:3] Set("PJSIP/3000019-000001a0", "CALLER_COS_ID=1") in new stack
-- Executing [s@sub-check-cos-privacy:4] Set("PJSIP/3000019-000001a0", "CALLER_COS_NAME=cos-all") in new stack
-- Executing [s@sub-check-cos-privacy:5] Set("PJSIP/3000019-000001a0", "CALLED_COS_ID=1") in new stack
-- Executing [s@sub-check-cos-privacy:6] GotoIf("PJSIP/3000019-000001a0", "1?same_cos") in new stack
-- Goto (sub-check-cos-privacy,s,17)
-- Executing [s@sub-check-cos-privacy:17] NoOp("PJSIP/3000019-000001a0", "The caller CoS and Callee CoS are the same") in new stack
-- Executing [s@sub-check-cos-privacy:18] Goto("PJSIP/3000019-000001a0", "return") in new stack
-- Goto (sub-check-cos-privacy,s,22)
-- Executing [s@sub-check-cos-privacy:22] Return("PJSIP/3000019-000001a0", "") in new stack
-- Executing [333@sub-local-dialing:8] Set("PJSIP/3000019-000001a0", "DIAL_STRING=PJSIP/333_1&PJSIP/333&Local/7010@cos-all") in new stack
-- Executing [333@sub-local-dialing:9] Set("PJSIP/3000019-000001a0", "DB(6787bde866811108/LASTCALLER/333)=3000019") in new stack
-- Executing [333@sub-local-dialing:10] Set("PJSIP/3000019-000001a0", "IGNORE_DIVERSIONS=") in new stack
-- Executing [333@sub-local-dialing:11] Set("PJSIP/3000019-000001a0", "QUEUE_CALL=") in new stack
-- Executing [333@sub-local-dialing:12] GosubIf("PJSIP/3000019-000001a0", "0?sub-queue-members,s,1") in new stack
-- Executing [333@sub-local-dialing:13] GosubIf("PJSIP/3000019-000001a0", "0?:sub-check-diversions,s,1(predialing)") in new stack
-- Executing [s@sub-check-diversions:1] NoOp("PJSIP/3000019-000001a0", "Checking diversions for extension 333") in new stack
-- Executing [s@sub-check-diversions:2] Set("PJSIP/3000019-000001a0", "OLD_CALLER_ID="3000019" <3000019>") in new stack
-- Executing [s@sub-check-diversions:3] GosubIf("PJSIP/3000019-000001a0", "0?:return") in new stack
-- Executing [s@sub-check-diversions:9] Return("PJSIP/3000019-000001a0", "") in new stack
-- Executing [s@sub-check-diversions:4] ExecIf("PJSIP/3000019-000001a0", "0?Set(CALLERID(all)="Asmar Kahn" <333>)") in new stack
-- Executing [s@sub-check-diversions:5] Set("PJSIP/3000019-000001a0", "__CALL_ORIGIN=diversions") in new stack
-- Executing [s@sub-check-diversions:6] Set("PJSIP/3000019-000001a0", "__DIVERSION_ORIGIN=333") in new stack
-- Executing [s@sub-check-diversions:7] Gosub("PJSIP/3000019-000001a0", "s-predialing,1") in new stack
-- Executing [s-predialing@sub-check-diversions:1] NoOp("PJSIP/3000019-000001a0", "Diversions on pre-dialing") in new stack
-- Executing [s-predialing@sub-check-diversions:2] GosubIf("PJSIP/3000019-000001a0", "0?:diversion-testing,1(Do not Disturb,DND,,,dnd)") in new stack
-- Executing [diversion-testing@sub-check-diversions:1] NoOp("PJSIP/3000019-000001a0", "") in new stack
-- Executing [diversion-testing@sub-check-diversions:2] Set("PJSIP/3000019-000001a0", "FROM_NUMBER=333") in new stack
-- Executing [diversion-testing@sub-check-diversions:3] GotoIf("PJSIP/3000019-000001a0", "0?:next-diversion") in new stack
-- Goto (sub-check-diversions,diversion-testing,36)
-- Executing [diversion-testing@sub-check-diversions:36] Return("PJSIP/3000019-000001a0", "") in new stack
-- Executing [s-predialing@sub-check-diversions:3] Gosub("PJSIP/3000019-000001a0", "diversion-testing,1(Call Forward Immeditely,CFI,,,toggle_cfi)") in new stack
-- Executing [s-predialing@sub-check-diversions:4] GosubIf("PJSIP/3000019-000001a0", "0?:diversion-testing,1(Boss Secretray,BOSS,,,boss_secretary)") in new stack
-- Executing [s-predialing@sub-check-diversions:5] GosubIf("PJSIP/3000019-000001a0", "0?:diversion-testing,1(Personal Assistant,PEA,sub-personal-assistant,s,1)") in new stack
-- Executing [s-predialing@sub-check-diversions:6] Return("PJSIP/3000019-000001a0", "") in new stack
-- Executing [s@sub-check-diversions:8] Set("PJSIP/3000019-000001a0", "CALLERID(all)="3000019" <3000019>") in new stack
-- Executing [333@sub-local-dialing:14] GotoIf("PJSIP/3000019-000001a0", "0?post-dial") in new stack
-- Executing [333@sub-local-dialing:15] Gosub("PJSIP/3000019-000001a0", "parse-dial-string,s,1") in new stack
-- Executing [s@parse-dial-string:1] NoOp("PJSIP/3000019-000001a0", "Parsing dial string: PJSIP/333_1&PJSIP/333&Local/7010@cos-all") in new stack
-- Executing [s@parse-dial-string:2] Set("PJSIP/3000019-000001a0", "NEW_DIAL_STRING=") in new stack
-- Executing [s@parse-dial-string:3] Set("PJSIP/3000019-000001a0", "COUNTER=1") in new stack
-- Executing [s@parse-dial-string:4] Set("PJSIP/3000019-000001a0", "CURRENT_DEVICE=PJSIP/333_1") in new stack
-- Executing [s@parse-dial-string:5] While("PJSIP/3000019-000001a0", "1") in new stack
-- Executing [s@parse-dial-string:6] Set("PJSIP/3000019-000001a0", "TECHNOLOGY=PJSIP") in new stack
-- Executing [s@parse-dial-string:7] Set("PJSIP/3000019-000001a0", "USER=333_1") in new stack
-- Executing [s@parse-dial-string:8] GotoIf("PJSIP/3000019-000001a0", "1?:regular") in new stack
-- Executing [s@parse-dial-string:9] Goto("PJSIP/3000019-000001a0", "regular-pjsip") in new stack
-- Goto (parse-dial-string,s,12)
-- Executing [s@parse-dial-string:12] Set("PJSIP/3000019-000001a0", "PARSED_DEV=PJSIP/333_1/sip:72.39.80.82:50173;transport=ws") in new stack
-- Executing [s@parse-dial-string:13] ExecIf("PJSIP/3000019-000001a0", "0?Set(PARSED_DEV=PJSIP/333_1)") in new stack
-- Executing [s@parse-dial-string:14] Goto("PJSIP/3000019-000001a0", "append") in new stack
-- Goto (parse-dial-string,s,16)
-- Executing [s@parse-dial-string:16] GotoIf("PJSIP/3000019-000001a0", "1?:concatenate") in new stack
-- Executing [s@parse-dial-string:17] Set("PJSIP/3000019-000001a0", "NEW_DIAL_STRING=PJSIP/333_1/sip:72.39.80.82:50173;transport=ws") in new stack
-- Executing [s@parse-dial-string:18] Goto("PJSIP/3000019-000001a0", "next") in new stack
-- Goto (parse-dial-string,s,21)
-- Executing [s@parse-dial-string:21] Set("PJSIP/3000019-000001a0", "COUNTER=2") in new stack
-- Executing [s@parse-dial-string:22] Set("PJSIP/3000019-000001a0", "CURRENT_DEVICE=PJSIP/333") in new stack
-- Executing [s@parse-dial-string:23] EndWhile("PJSIP/3000019-000001a0", "") in new stack
-- Executing [s@parse-dial-string:7] Set("PJSIP/3000019-000001a0", "USER=333") in new stack
-- Executing [s@parse-dial-string:12] Set("PJSIP/3000019-000001a0", "PARSED_DEV=") in new stack
-- Executing [s@parse-dial-string:13] ExecIf("PJSIP/3000019-000001a0", "1?Set(PARSED_DEV=PJSIP/333)") in new stack
-- Executing [s@parse-dial-string:16] GotoIf("PJSIP/3000019-000001a0", "0?:concatenate") in new stack
-- Goto (parse-dial-string,s,19)
-- Executing [s@parse-dial-string:19] GotoIf("PJSIP/3000019-000001a0", "1?:next") in new stack
-- Executing [s@parse-dial-string:20] Set("PJSIP/3000019-000001a0", "NEW_DIAL_STRING=PJSIP/333_1/sip:72.39.80.82:50173;transport=ws&PJSIP/333") in new stack
-- Executing [s@parse-dial-string:21] Set("PJSIP/3000019-000001a0", "COUNTER=3") in new stack
-- Executing [s@parse-dial-string:22] Set("PJSIP/3000019-000001a0", "CURRENT_DEVICE=Local/7010@cos-all") in new stack
-- Executing [s@parse-dial-string:6] Set("PJSIP/3000019-000001a0", "TECHNOLOGY=Local") in new stack
-- Executing [s@parse-dial-string:7] Set("PJSIP/3000019-000001a0", "USER=7010@cos-all") in new stack
-- Executing [s@parse-dial-string:8] GotoIf("PJSIP/3000019-000001a0", "0?:regular") in new stack
-- Goto (parse-dial-string,s,15)
-- Executing [s@parse-dial-string:15] Set("PJSIP/3000019-000001a0", "PARSED_DEV=Local/7010@cos-all") in new stack
-- Executing [s@parse-dial-string:20] Set("PJSIP/3000019-000001a0", "NEW_DIAL_STRING=PJSIP/333_1/sip:72.39.80.82:50173;transport=ws&PJSIP/333&Local/7010@cos-all") in new stack
-- Executing [s@parse-dial-string:21] Set("PJSIP/3000019-000001a0", "COUNTER=4") in new stack
-- Executing [s@parse-dial-string:22] Set("PJSIP/3000019-000001a0", "CURRENT_DEVICE=") in new stack
-- Executing [s@parse-dial-string:5] While("PJSIP/3000019-000001a0", "0") in new stack
-- Executing [s@parse-dial-string:24] NoOp("PJSIP/3000019-000001a0", "New dialstring: PJSIP/333_1/sip:72.39.80.82:50173;transport=ws&PJSIP/333&Local/7010@cos-all") in new stack
-- Executing [s@parse-dial-string:25] Set("PJSIP/3000019-000001a0", "DIAL_STRING=PJSIP/333_1/sip:72.39.80.82:50173;transport=ws&PJSIP/333&Local/7010@cos-all") in new stack
-- Executing [s@parse-dial-string:26] Return("PJSIP/3000019-000001a0", "") in new stack
-- Executing [333@sub-local-dialing:16] NoOp("PJSIP/3000019-000001a0", "Configuring Dial Settings") in new stack
-- Executing [333@sub-local-dialing:17] Set("PJSIP/3000019-000001a0", "RING_TIME=30") in new stack
-- Executing [333@sub-local-dialing:18] Set("PJSIP/3000019-000001a0", "RING_TIME=30") in new stack
-- Executing [333@sub-local-dialing:19] Set("PJSIP/3000019-000001a0", "RING_TIME=30") in new stack
-- Executing [333@sub-local-dialing:20] Set("PJSIP/3000019-000001a0", "DIAL_OPTIONS=kKtrU(GLPI-notify-OPS)") in new stack
-- Executing [333@sub-local-dialing:21] Set("PJSIP/3000019-000001a0", "DIAL_OPTIONS=kKtrU(GLPI-notify-OPS)") in new stack
-- Executing [333@sub-local-dialing:22] GotoIf("PJSIP/3000019-000001a0", "0?:answermode") in new stack
-- Goto (sub-local-dialing,333,26)
-- Executing [333@sub-local-dialing:26] Set("PJSIP/3000019-000001a0", "ANSWER_MODE=disable") in new stack
-- Executing [333@sub-local-dialing:27] Set("PJSIP/3000019-000001a0", "ANSWER_MODE=disable") in new stack
-- Executing [333@sub-local-dialing:28] GotoIf("PJSIP/3000019-000001a0", "0?check-hd") in new stack
-- Executing [333@sub-local-dialing:29] ExecIf("PJSIP/3000019-000001a0", "0?Set(EXEC_AA=yes)") in new stack
-- Executing [333@sub-local-dialing:30] ExecIf("PJSIP/3000019-000001a0", "0?Set(EXEC_AA=yes)") in new stack
-- Executing [333@sub-local-dialing:31] Set("PJSIP/3000019-000001a0", "IS_HOT_DESK=no") in new stack
-- Executing [333@sub-local-dialing:32] Set("PJSIP/3000019-000001a0", "MOH_CLASS=default") in new stack
-- Executing [333@sub-local-dialing:33] GosubIf("PJSIP/3000019-000001a0", "0?sub-set-moh,s,1(default)") in new stack
-- Executing [333@sub-local-dialing:34] GotoIf("PJSIP/3000019-000001a0", "0?busy-here") in new stack
-- Executing [333@sub-local-dialing:35] Set("PJSIP/3000019-000001a0", "FORCE_RECORDING=no") in new stack
-- Executing [333@sub-local-dialing:36] Set("PJSIP/3000019-000001a0", "DIAL_OPTIONS=kKtrU(GLPI-notify-OPS)b(sub-before-connecting-call^s^1(6787bde866811108^3000019^333^^))") in new stack
-- Executing [333@sub-local-dialing:37] Set("PJSIP/3000019-000001a0", "DIAL_OPTIONS=kKtrU(GLPI-notify-OPS)b(sub-before-connecting-call^s^1(6787bde866811108^3000019^333^^))U(sub-before-bridging-call^6787bde866811108^3000019^333^no)") in new stack
-- Executing [333@sub-local-dialing:38] Set("PJSIP/3000019-000001a0", "__TRANSFERED_CALL=TRUE") in new stack
-- Executing [333@sub-local-dialing:39] NoOp("PJSIP/3000019-000001a0", "Enable Follow-Me Ring Time If needed") in new stack
-- Executing [333@sub-local-dialing:40] GotoIf("PJSIP/3000019-000001a0", "0?:check-rt") in new stack
-- Goto (sub-local-dialing,333,47)
-- Executing [333@sub-local-dialing:47] GotoIf("PJSIP/3000019-000001a0", "0?post-dial") in new stack
-- Executing [333@sub-local-dialing:48] GotoIf("PJSIP/3000019-000001a0", "0?end_call") in new stack
-- Executing [333@sub-local-dialing:49] Gosub("PJSIP/3000019-000001a0", "sub-udpate-virtual-dev-state,s,1(333,BUSY)") in new stack
-- Executing [s@sub-udpate-virtual-dev-state:1] NoOp("PJSIP/3000019-000001a0", "Update Virtual Devices State") in new stack
-- Executing [s@sub-udpate-virtual-dev-state:2] Set("PJSIP/3000019-000001a0", "EXT_NUM=333") in new stack
-- Executing [s@sub-udpate-virtual-dev-state:3] Set("PJSIP/3000019-000001a0", "NEW_STATUS=BUSY") in new stack
-- Executing [s@sub-udpate-virtual-dev-state:4] Set("PJSIP/3000019-000001a0", "EXTENSION_ID=7") in new stack
-- Executing [s@sub-udpate-virtual-dev-state:5] Set("PJSIP/3000019-000001a0", "ODBC_ID=635") in new stack
-- Executing [s@sub-udpate-virtual-dev-state:6] GotoIf("PJSIP/3000019-000001a0", "0?no_rows") in new stack
-- Executing [s@sub-udpate-virtual-dev-state:7] Set("PJSIP/3000019-000001a0", "COUNTER=1") in new stack
-- Executing [s@sub-udpate-virtual-dev-state:8] While("PJSIP/3000019-000001a0", "1") in new stack
-- Executing [s@sub-udpate-virtual-dev-state:9] Set("PJSIP/3000019-000001a0", "VDevice=33") in new stack
-- Executing [s@sub-udpate-virtual-dev-state:10] Set("PJSIP/3000019-000001a0", "DEVICE_STATE(Custom:VirtualDev33)=BUSY") in new stack
-- Executing [s@sub-udpate-virtual-dev-state:11] Set("PJSIP/3000019-000001a0", "COUNTER=2") in new stack
-- Executing [s@sub-udpate-virtual-dev-state:12] EndWhile("PJSIP/3000019-000001a0", "") in new stack
-- Executing [s@sub-udpate-virtual-dev-state:8] While("PJSIP/3000019-000001a0", "0") in new stack
-- Executing [s@sub-udpate-virtual-dev-state:13] ODBCFinish("PJSIP/3000019-000001a0", "") in new stack
-- Executing [s@sub-udpate-virtual-dev-state:14] Return("PJSIP/3000019-000001a0", "") in new stack
-- Executing [333@sub-local-dialing:50] Dial("PJSIP/3000019-000001a0", "PJSIP/333_1/sip:72.39.80.82:50173;transport=ws&PJSIP/333&Local/7010@cos-all,30,kKtrU(GLPI-notify-OPS)b(sub-before-connecting-call^s^1(6787bde866811108^3000019^333^^))U(sub-before-bridging-call^6787bde866811108^3000019^333^no)") in new stack
[2022-09-01 06:17:31] ERROR[27962]: res_pjsip.c:4096 ast_sip_create_dialog_uac: Endpoint '333': Could not create dialog to invalid URI '333'. Is endpoint registered and reachable?
[2022-09-01 06:17:31] ERROR[27962]: chan_pjsip.c:2657 request: Failed to create outgoing session to endpoint '333'
[2022-09-01 06:17:31] WARNING[18606][C-00000341]: app_dial.c:2663 dial_exec_full: Unable to create channel of type 'PJSIP' (cause 3 - No route to destination)
-- PJSIP/333_1-000001a1 Internal Gosub(sub-before-connecting-call,s,1(6787bde866811108,3000019,333,,)) start
-- Executing [s@sub-before-connecting-call:1] NoOp("PJSIP/333_1-000001a1", "Executing routines in the newly created channel before initiaing the call") in new stack
-- Executing [s@sub-before-connecting-call:2] Set("PJSIP/333_1-000001a1", "TENANT=6787bde866811108") in new stack
-- Executing [s@sub-before-connecting-call:3] Set("PJSIP/333_1-000001a1", "CALLER=3000019") in new stack
-- Executing [s@sub-before-connecting-call:4] Set("PJSIP/333_1-000001a1", "CALLEE=333") in new stack
-- Executing [s@sub-before-connecting-call:5] Set("PJSIP/333_1-000001a1", "EXEC_AA=") in new stack
-- Executing [s@sub-before-connecting-call:6] Set("PJSIP/333_1-000001a1", "CUSTOM_ALERT_INFO=") in new stack
-- Executing [s@sub-before-connecting-call:7] Set("PJSIP/333_1-000001a1", "APP_TYPE=NONE") in new stack
-- Executing [s@sub-before-connecting-call:8] GosubIf("PJSIP/333_1-000001a1", "0?sub-auto-answer,s,1") in new stack
-- Executing [s@sub-before-connecting-call:9] GosubIf("PJSIP/333_1-000001a1", "0?sub-set-custom-header,s,1(Alert-Info,)") in new stack
-- Executing [s@sub-before-connecting-call:10] GosubIf("PJSIP/333_1-000001a1", "0?sub-set-custom-header,s,1(Call-Info,)") in new stack
-- Executing [s@sub-before-connecting-call:11] Gosub("PJSIP/333_1-000001a1", "sub-set-custom-header,s,1(CALL-TYPE,LOCAL)") in new stack
-- Executing [s@sub-set-custom-header:1] NoOp("PJSIP/333_1-000001a1", "Setting up custom header") in new stack
-- Executing [s@sub-set-custom-header:2] GotoIf("PJSIP/333_1-000001a1", "0?set-sip") in new stack
-- Executing [s@sub-set-custom-header:3] NoOp("PJSIP/333_1-000001a1", "Add PJSIP Headers") in new stack
-- Executing [s@sub-set-custom-header:4] Set("PJSIP/333_1-000001a1", "PJSIP_HEADER(add,CALL-TYPE)=LOCAL") in new stack
-- Executing [s@sub-set-custom-header:5] Goto("PJSIP/333_1-000001a1", "end") in new stack
-- Goto (sub-set-custom-header,s,8)
-- Executing [s@sub-set-custom-header:8] Return("PJSIP/333_1-000001a1", "") in new stack
-- Executing [s@sub-before-connecting-call:12] Gosub("PJSIP/333_1-000001a1", "sub-set-custom-header,s,1(APPLICATION,NONE)") in new stack
-- Executing [s@sub-set-custom-header:4] Set("PJSIP/333_1-000001a1", "PJSIP_HEADER(add,APPLICATION)=NONE") in new stack
-- Executing [s@sub-before-connecting-call:13] GosubIf("PJSIP/333_1-000001a1", "0?sub-set-custom-header,s,1(QUEUE-NAME,)") in new stack
-- Executing [s@sub-before-connecting-call:14] GosubIf("PJSIP/333_1-000001a1", "0?before-connecting-call-hook,s,1") in new stack
-- Executing [s@sub-before-connecting-call:15] Return("PJSIP/333_1-000001a1", "") in new stack
== Spawn extension (cos-all, 333, 1) exited non-zero on 'PJSIP/333_1-000001a1'
-- PJSIP/333_1-000001a1 Internal Gosub(sub-before-connecting-call,s,1(6787bde866811108,3000019,333,,)) complete GOSUB_RETVAL=
-- Local/7010@cos-all-0000013b;1 Internal Gosub(sub-before-connecting-call,s,1(6787bde866811108,3000019,333,,)) start
-- Executing [s@sub-before-connecting-call:1] NoOp("Local/7010@cos-all-0000013b;1", "Executing routines in the newly created channel before initiaing the call") in new stack
-- Executing [s@sub-before-connecting-call:2] Set("Local/7010@cos-all-0000013b;1", "TENANT=6787bde866811108") in new stack
-- Executing [s@sub-before-connecting-call:3] Set("Local/7010@cos-all-0000013b;1", "CALLER=3000019") in new stack
-- Executing [s@sub-before-connecting-call:4] Set("Local/7010@cos-all-0000013b;1", "CALLEE=333") in new stack
-- Executing [s@sub-before-connecting-call:5] Set("Local/7010@cos-all-0000013b;1", "EXEC_AA=") in new stack
-- Executing [s@sub-before-connecting-call:6] Set("Local/7010@cos-all-0000013b;1", "CUSTOM_ALERT_INFO=") in new stack
-- Executing [s@sub-before-connecting-call:7] Set("Local/7010@cos-all-0000013b;1", "APP_TYPE=NONE") in new stack
-- Executing [s@sub-before-connecting-call:8] GosubIf("Local/7010@cos-all-0000013b;1", "0?sub-auto-answer,s,1") in new stack
-- Executing [s@sub-before-connecting-call:9] GosubIf("Local/7010@cos-all-0000013b;1", "0?sub-set-custom-header,s,1(Alert-Info,)") in new stack
-- Executing [s@sub-before-connecting-call:10] GosubIf("Local/7010@cos-all-0000013b;1", "0?sub-set-custom-header,s,1(Call-Info,)") in new stack
-- Executing [s@sub-before-connecting-call:11] Gosub("Local/7010@cos-all-0000013b;1", "sub-set-custom-header,s,1(CALL-TYPE,LOCAL)") in new stack
-- Executing [s@sub-set-custom-header:1] NoOp("Local/7010@cos-all-0000013b;1", "Setting up custom header") in new stack
-- Executing [s@sub-set-custom-header:2] GotoIf("Local/7010@cos-all-0000013b;1", "0?set-sip") in new stack
-- Executing [s@sub-set-custom-header:3] NoOp("Local/7010@cos-all-0000013b;1", "Add PJSIP Headers") in new stack
-- Executing [s@sub-set-custom-header:4] Set("Local/7010@cos-all-0000013b;1", "PJSIP_HEADER(add,CALL-TYPE)=LOCAL") in new stack
[2022-09-01 06:17:31] ERROR[18606][C-00000341]: res_pjsip_header_funcs.c:680 func_write_header: This function requires a PJSIP channel.
-- Executing [s@sub-set-custom-header:5] Goto("Local/7010@cos-all-0000013b;1", "end") in new stack
-- Executing [s@sub-set-custom-header:8] Return("Local/7010@cos-all-0000013b;1", "") in new stack
-- Executing [s@sub-before-connecting-call:12] Gosub("Local/7010@cos-all-0000013b;1", "sub-set-custom-header,s,1(APPLICATION,NONE)") in new stack
-- Executing [s@sub-set-custom-header:4] Set("Local/7010@cos-all-0000013b;1", "PJSIP_HEADER(add,APPLICATION)=NONE") in new stack
-- Executing [s@sub-before-connecting-call:13] GosubIf("Local/7010@cos-all-0000013b;1", "0?sub-set-custom-header,s,1(QUEUE-NAME,)") in new stack
-- Executing [s@sub-before-connecting-call:14] GosubIf("Local/7010@cos-all-0000013b;1", "0?before-connecting-call-hook,s,1") in new stack
-- Executing [s@sub-before-connecting-call:15] Return("Local/7010@cos-all-0000013b;1", "") in new stack
== Spawn extension (cos-all, 333, 1) exited non-zero on 'Local/7010@cos-all-0000013b;1'
-- Local/7010@cos-all-0000013b;1 Internal Gosub(sub-before-connecting-call,s,1(6787bde866811108,3000019,333,,)) complete GOSUB_RETVAL=
-- Called PJSIP/333_1/sip:72.39.80.82:50173;transport=ws
-- Called Local/7010@cos-all
-- Executing [7010@cos-all:1] NoOp("Local/7010@cos-all-0000013b;2", "More than on digit pattern") in new stack
-- Executing [7010@cos-all:2] Gosub("Local/7010@cos-all-0000013b;2", "s,1(7010)") in new stack
-- Executing [s@cos-all:1] Set("Local/7010@cos-all-0000013b;2", "EXTENSION=7010") in new stack
-- Executing [s@cos-all:2] NoOp("Local/7010@cos-all-0000013b;2", "Dialing 7010 from 3000019") in new stack
-- Executing [s@cos-all:3] Gosub("Local/7010@cos-all-0000013b;2", "sub-set-global-vars,s,1(6787bde866811108,7010,parking-1)") in new stack
-- Executing [s@sub-set-global-vars:1] NoOp("Local/7010@cos-all-0000013b;2", "Setting Global Vars") in new stack
-- Executing [s@sub-set-global-vars:2] Set("Local/7010@cos-all-0000013b;2", "TENANT_PATH=6787bde866811108") in new stack
-- Executing [s@sub-set-global-vars:3] Set("Local/7010@cos-all-0000013b;2", "PREFIX=") in new stack
-- Executing [s@sub-set-global-vars:4] Set("Local/7010@cos-all-0000013b;2", "__PICKUPMARK=7010") in new stack
-- Executing [s@sub-set-global-vars:5] Set("Local/7010@cos-all-0000013b;2", "__PARKINGLOT=parking-1") in new stack
-- Executing [s@sub-set-global-vars:6] Set("Local/7010@cos-all-0000013b;2", "__DYNAMIC_FEATURES=custom-features") in new stack
-- Executing [s@sub-set-global-vars:7] Set("Local/7010@cos-all-0000013b;2", "ICALL=no") in new stack
-- Executing [s@sub-set-global-vars:8] Return("Local/7010@cos-all-0000013b;2", "") in new stack
-- Executing [s@cos-all:4] Gosub("Local/7010@cos-all-0000013b;2", "sub-set-call-vars,s,1(6787bde866811108,7010,1,cos-all,ARS-all)") in new stack
-- Executing [s@sub-set-call-vars:1] NoOp("Local/7010@cos-all-0000013b;2", "Setting Call Vars") in new stack
-- Executing [s@sub-set-call-vars:2] Set("Local/7010@cos-all-0000013b;2", "_TENANT=6787bde866811108") in new stack
-- Executing [s@sub-set-call-vars:3] Set("Local/7010@cos-all-0000013b;2", "_CALL_DESTINATION=7010") in new stack
-- Executing [s@sub-set-call-vars:4] Set("Local/7010@cos-all-0000013b;2", "_COS_ID=1") in new stack
-- Executing [s@sub-set-call-vars:5] Set("Local/7010@cos-all-0000013b;2", "_COS_NAME=cos-all") in new stack
-- Executing [s@sub-set-call-vars:6] Set("Local/7010@cos-all-0000013b;2", "__TRANSFER_CONTEXT=cos-all") in new stack
-- Executing [s@sub-set-call-vars:7] Set("Local/7010@cos-all-0000013b;2", "_ARS=ARS-all") in new stack
-- Executing [s@sub-set-call-vars:8] Set("Local/7010@cos-all-0000013b;2", "CDR(tenant)=vitalpbx") in new stack
-- Executing [s@sub-set-call-vars:9] Set("Local/7010@cos-all-0000013b;2", "CDR(destination)=7010") in new stack
-- Executing [s@sub-set-call-vars:10] Set("Local/7010@cos-all-0000013b;2", "CDR(trunk)=") in new stack
-- Executing [s@sub-set-call-vars:11] Set("Local/7010@cos-all-0000013b;2", "CDR(did)=") in new stack
-- Executing [s@sub-set-call-vars:12] Set("Local/7010@cos-all-0000013b;2", "__CALLID=1662005851.1823") in new stack
-- Executing [s@sub-set-call-vars:13] ExecIf("Local/7010@cos-all-0000013b;2", "0?Set(CHANNEL(language)=)") in new stack
-- Executing [s@sub-set-call-vars:14] ExecIf("Local/7010@cos-all-0000013b;2", "1?Set(CHANNEL(language)=en)") in new stack
-- Executing [s@sub-set-call-vars:15] Return("Local/7010@cos-all-0000013b;2", "") in new stack
-- Executing [s@cos-all:5] Gosub("Local/7010@cos-all-0000013b;2", "sub-construct-cid,s,1") in new stack
-- Executing [s@sub-construct-cid:1] NoOp("Local/7010@cos-all-0000013b;2", "Building CID") in new stack
-- Executing [s@sub-construct-cid:2] Set("Local/7010@cos-all-0000013b;2", "_CALL_SOURCE=3000019") in new stack
-- Executing [s@sub-construct-cid:3] Set("Local/7010@cos-all-0000013b;2", "_CS=3000019") in new stack
-- Executing [s@sub-construct-cid:4] GotoIf("Local/7010@cos-all-0000013b;2", "1?return") in new stack
-- Goto (sub-construct-cid,s,11)
-- Executing [s@sub-construct-cid:11] NoOp("Local/7010@cos-all-0000013b;2", "") in new stack
-- Executing [s@sub-construct-cid:12] Set("Local/7010@cos-all-0000013b;2", "CDR(source)=3000019") in new stack
-- Executing [s@sub-construct-cid:13] Return("Local/7010@cos-all-0000013b;2", "") in new stack
-- Executing [s@cos-all:6] Gosub("Local/7010@cos-all-0000013b;2", "set-global-tenant-vars,s,1") in new stack
-- Executing [s@set-global-tenant-vars:1] NoOp("Local/7010@cos-all-0000013b;2", "Setting Global Vars for vitalpbx Tenant") in new stack
-- Executing [s@set-global-tenant-vars:2] Set("Local/7010@cos-all-0000013b;2", "__TENANT_PATH=6787bde866811108") in new stack
-- Executing [s@set-global-tenant-vars:3] Set("Local/7010@cos-all-0000013b;2", "__TENANT_PREFIX=") in new stack
-- Executing [s@set-global-tenant-vars:4] Set("Local/7010@cos-all-0000013b;2", "__QUEUE_AGENTS_CONTEXT=queue-call-to-agents") in new stack
-- Executing [s@set-global-tenant-vars:5] Set("Local/7010@cos-all-0000013b;2", "__FOLLOWME_CONTEXT=ext-followme") in new stack
-- Executing [s@set-global-tenant-vars:6] Set("Local/7010@cos-all-0000013b;2", "__HINTS_CONTEXT=extension-hints") in new stack
-- Executing [s@set-global-tenant-vars:7] Set("Local/7010@cos-all-0000013b;2", "__DEFAULT_COS=cos-all") in new stack
-- Executing [s@set-global-tenant-vars:8] Return("Local/7010@cos-all-0000013b;2", "") in new stack
-- Executing [s@cos-all:7] GotoIf("Local/7010@cos-all-0000013b;2", "0?local-dialing") in new stack
-- Executing [s@cos-all:8] NoOp("Local/7010@cos-all-0000013b;2", "Check if is an Emergency Call") in new stack
-- Executing [s@cos-all:9] GotoIf("Local/7010@cos-all-0000013b;2", "0?emergency-calls,7010,1") in new stack
-- Executing [s@cos-all:10] Gosub("Local/7010@cos-all-0000013b;2", "sub-lockphone-check,s,1") in new stack
-- Executing [s@sub-lockphone-check:1] NoOp("Local/7010@cos-all-0000013b;2", "SUB: LOCK PHONE CHECK") in new stack
-- Executing [s@sub-lockphone-check:2] GotoIf("Local/7010@cos-all-0000013b;2", "0?unlock") in new stack
-- Executing [s@sub-lockphone-check:3] GotoIf("Local/7010@cos-all-0000013b;2", "0?unlock") in new stack
-- Executing [s@sub-lockphone-check:4] GotoIf("Local/7010@cos-all-0000013b;2", "0?unlock") in new stack
-- Executing [s@sub-lockphone-check:5] GotoIf("Local/7010@cos-all-0000013b;2", "0?unlock") in new stack
-- Executing [s@sub-lockphone-check:6] GotoIf("Local/7010@cos-all-0000013b;2", "0?:unlock") in new stack
-- Executing [s@sub-lockphone-check:12] Return("Local/7010@cos-all-0000013b;2", "") in new stack
-- Executing [s@cos-all:11] Gosub("Local/7010@cos-all-0000013b;2", "sub-local-dialing,s,1") in new stack
-- Executing [s@sub-local-dialing:1] NoOp("Local/7010@cos-all-0000013b;2", "Trying to determine if is a local extension") in new stack
-- Executing [s@sub-local-dialing:2] GotoIf("Local/7010@cos-all-0000013b;2", "0?:return") in new stack
-- Executing [s@sub-local-dialing:5] Return("Local/7010@cos-all-0000013b;2", "") in new stack
-- Executing [s@cos-all:12] GotoIf("Local/7010@cos-all-0000013b;2", "0?end-call") in new stack
-- Executing [s@cos-all:13] Goto("Local/7010@cos-all-0000013b;2", "cos-all-post,7010,1") in new stack
-- Goto (cos-all-post,7010,1)
-- Executing [7010@cos-all-post:1] Gosub("Local/7010@cos-all-0000013b;2", "sub-set-call-vars,app-incoming,1") in new stack
-- Executing [app-incoming@sub-set-call-vars:1] NoOp("Local/7010@cos-all-0000013b;2", "Incoming Call App CDR") in new stack
-- Executing [app-incoming@sub-set-call-vars:2] GotoIf("Local/7010@cos-all-0000013b;2", "0?:return") in new stack
-- Goto (sub-set-call-vars,app-incoming,6)
-- Executing [app-incoming@sub-set-call-vars:6] Return("Local/7010@cos-all-0000013b;2", "") in new stack
-- Executing [7010@cos-all-post:2] NoOp("Local/7010@cos-all-0000013b;2", "Custom Application: GLPI-notify-OPS") in new stack
-- Executing [7010@cos-all-post:3] Goto("Local/7010@cos-all-0000013b;2", "custom-contexts,cc-6,1") in new stack
-- Goto (custom-contexts,cc-6,1)
-- Executing [cc-6@custom-contexts:1] NoOp("Local/7010@cos-all-0000013b;2", "GLPI-notify-OPS") in new stack
-- Executing [cc-6@custom-contexts:2] Gosub("Local/7010@cos-all-0000013b;2", "before-bridging-call-hook,GLPI-Support,1(app-termination,hangup,1)") in new stack
[2022-09-01 06:17:31] ERROR[18607][C-00000341]: app_stack.c:593 gosub_exec: Gosub attempted to reach non-existent destination 'before-bridging-call-hook,GLPI-Support,1' from 'custom-contexts,cc-6,2'
== Spawn extension (custom-contexts, cc-6, 2) exited non-zero on 'Local/7010@cos-all-0000013b;2'
== DTLS ECDH initialized (automatic), faster PFS enabled
-- PJSIP/333_1-000001a1 connected line has changed. Saving it until answer for PJSIP/3000019-000001a0
-- PJSIP/333_1-000001a1 is ringing
> 0x7f9f7425e370 -- Strict RTP learning after remote address set to: 72.39.80.82:54314
-- PJSIP/333_1-000001a1 answered PJSIP/3000019-000001a0
-- PJSIP/333_1-000001a1 Internal Gosub(sub-before-bridging-call,s,1(6787bde866811108,3000019,333,no)) start
-- Executing [s@sub-before-bridging-call:1] NoOp("PJSIP/333_1-000001a1", "Executing sub-routine before connecting to the calling channel") in new stack
-- Executing [s@sub-before-bridging-call:2] Set("PJSIP/333_1-000001a1", "TENANT=6787bde866811108") in new stack
-- Executing [s@sub-before-bridging-call:3] Set("PJSIP/333_1-000001a1", "CALLER=3000019") in new stack
-- Executing [s@sub-before-bridging-call:4] Set("PJSIP/333_1-000001a1", "CALLEE=333") in new stack
-- Executing [s@sub-before-bridging-call:5] Set("PJSIP/333_1-000001a1", "FORCE_CALL_RECORDING=no") in new stack
-- Executing [s@sub-before-bridging-call:6] NoOp("PJSIP/333_1-000001a1", "Check if the follow-me confirmation sub-routine needs to be executed") in new stack
-- Executing [s@sub-before-bridging-call:7] GotoIf("PJSIP/333_1-000001a1", "1?call-recording") in new stack
-- Goto (sub-before-bridging-call,s,9)
-- Executing [s@sub-before-bridging-call:9] NoOp("PJSIP/333_1-000001a1", "Executing the call-recording sub-routine") in new stack
-- Executing [s@sub-before-bridging-call:10] Gosub("PJSIP/333_1-000001a1", "sub-call-recording,s,1(6787bde866811108,3000019,333,no)") in new stack
-- Executing [s@sub-call-recording:1] NoOp("PJSIP/333_1-000001a1", "Check if call will be recorded on tenant 6787bde866811108") in new stack
-- Executing [s@sub-call-recording:2] NoOp("PJSIP/333_1-000001a1", "Call Type: 1 ") in new stack
-- Executing [s@sub-call-recording:3] Set("PJSIP/333_1-000001a1", "TENANT=6787bde866811108") in new stack
-- Executing [s@sub-call-recording:4] Set("PJSIP/333_1-000001a1", "CALLER=3000019") in new stack
-- Executing [s@sub-call-recording:5] Set("PJSIP/333_1-000001a1", "CALLEE=333") in new stack
-- Executing [s@sub-call-recording:6] Set("PJSIP/333_1-000001a1", "APP_FORCE=no") in new stack
-- Executing [s@sub-call-recording:7] GotoIf("PJSIP/333_1-000001a1", "1?:rec_no_available") in new stack
-- Executing [s@sub-call-recording:8] GotoIf("PJSIP/333_1-000001a1", "0?perform-recording") in new stack
-- Executing [s@sub-call-recording:9] GotoIf("PJSIP/333_1-000001a1", "1?perform-recording") in new stack
-- Goto (sub-call-recording,s,14)
-- Executing [s@sub-call-recording:14] Gosub("PJSIP/333_1-000001a1", "sub-perform-recording,s,1") in new stack
-- Executing [s@sub-perform-recording:1] NoOp("PJSIP/333_1-000001a1", "Perform Call Recording") in new stack
-- Executing [s@sub-perform-recording:2] Set("PJSIP/333_1-000001a1", "RECORDING_ID=1662005851.1821") in new stack
-- Executing [s@sub-perform-recording:3] Set("PJSIP/333_1-000001a1", "APP_TYPE=NONE") in new stack
-- Executing [s@sub-perform-recording:4] Set("PJSIP/333_1-000001a1", "AUDIO_FILE=061733-LOCAL-NONE-3000019-333-1662005851.1821") in new stack
-- Executing [s@sub-perform-recording:5] Set("PJSIP/333_1-000001a1", "RECORDING_FORMAT=wav") in new stack
-- Executing [s@sub-perform-recording:6] Set("PJSIP/333_1-000001a1", "__REC_FILENAME=/var/spool/asterisk/monitor/2022/09/01/061733-LOCAL-NONE-3000019-333-1662005851.1821.wav") in new stack
-- Executing [s@sub-perform-recording:7] GotoIf("PJSIP/333_1-000001a1", "0?:set_rec_file") in new stack
-- Goto (sub-perform-recording,s,10)
-- Executing [s@sub-perform-recording:10] Set("PJSIP/333_1-000001a1", "CDR(recfile)=/var/spool/asterisk/monitor/2022/09/01/061733-LOCAL-NONE-3000019-333-1662005851.1821.wav") in new stack
-- Executing [s@sub-perform-recording:11] MixMonitor("PJSIP/333_1-000001a1", "/var/spool/asterisk/monitor/2022/09/01/061733-LOCAL-NONE-3000019-333-1662005851.1821.wav,b,") in new stack
-- Executing [s@sub-perform-recording:12] Return("PJSIP/333_1-000001a1", "") in new stack
-- Executing [s@sub-call-recording:15] Goto("PJSIP/333_1-000001a1", "return") in new stack
-- Goto (sub-call-recording,s,17)
-- Executing [s@sub-call-recording:17] Return("PJSIP/333_1-000001a1", "") in new stack
-- Executing [s@sub-before-bridging-call:11] NoOp("PJSIP/333_1-000001a1", "Check if there's a custom sub-routine defined for executing it") in new stack
-- Executing [s@sub-before-bridging-call:12] GosubIf("PJSIP/333_1-000001a1", "1?before-bridging-call-hook,s,1") in new stack
-- Executing [s@before-bridging-call-hook:1] NoOp("PJSIP/333_1-000001a1", "Entering custom context before bridging the call") in new stack
-- Executing [s@before-bridging-call-hook:2] GosubIf("PJSIP/333_1-000001a1", "1?GLPI-notify-OPS,GLPI-Support,1") in new stack
-- Executing [GLPI-Support@GLPI-notify-OPS:1] Set("PJSIP/333_1-000001a1", "user=zammad") in new stack
-- Executing [GLPI-Support@GLPI-notify-OPS:2] Set("PJSIP/333_1-000001a1", "pass=zammad") in new stack
-- Executing [GLPI-Support@GLPI-notify-OPS:3] Set("PJSIP/333_1-000001a1", "schema=zammad_production") in new stack
-- Executing [GLPI-Support@GLPI-notify-OPS:4] Set("PJSIP/333_1-000001a1", "server=75.119.134.12") in new stack
== Begin MixMonitor Recording PJSIP/333_1-000001a1
-- Executing [GLPI-Support@GLPI-notify-OPS:5] Set("PJSIP/333_1-000001a1", "ARRAY(fname,lname,getemail,phone)=") in new stack
-- Executing [GLPI-Support@GLPI-notify-OPS:6] Set("PJSIP/333_1-000001a1", "sendemail=") in new stack
-- Executing [GLPI-Support@GLPI-notify-OPS:7] ExecIf("PJSIP/333_1-000001a1", "1?Set([email protected])") in new stack
> 0x7f9f7425e370 -- Strict RTP learning after ICE completion
> 0x7f9f7425e370 -- Strict RTP switching to RTP target address 72.39.80.82:54314 as source
-- Executing [GLPI-Support@GLPI-notify-OPS:8] Set("PJSIP/333_1-000001a1", "Answer=error: The login is not valid. Unable to add user. User: AgentBadge: 12 .... New user added successfully") in new stack
[2022-09-01 06:17:35] NOTICE[18606][C-00000341]: app_stack.c:1079 gosub_run: PJSIP/333_1-000001a1 Abnormal 'Gosub(sub-before-bridging-call,s,1(6787bde866811108,3000019,333,no))' exit. Popping routine return locations.
> 0x7f9f3c0aee90 -- Strict RTP learning after remote address set to: 192.168.1.18:5042
-- Channel PJSIP/333_1-000001a1 joined 'simple_bridge' basic-bridge <d8d6ef8c-4f0c-470f-beae-d628541ad6c7>
-- Channel PJSIP/333_1-000001a1 left 'simple_bridge' basic-bridge <d8d6ef8c-4f0c-470f-beae-d628541ad6c7>
== Spawn extension (sub-local-dialing, 333, 50) exited non-zero on 'PJSIP/3000019-000001a0'
-- Executing [h@sub-local-dialing:1] NoOp("PJSIP/3000019-000001a0", "Finishing the call") in new stack
-- Executing [h@sub-local-dialing:2] Gosub("PJSIP/3000019-000001a0", "sub-udpate-virtual-dev-state,s,1(333,NOT_INUSE)") in new stack
-- Executing [s@sub-udpate-virtual-dev-state:3] Set("PJSIP/3000019-000001a0", "NEW_STATUS=NOT_INUSE") in new stack
== MixMonitor close filestream (mixed)
== End MixMonitor Recording PJSIP/333_1-000001a1
-- Executing [s@sub-udpate-virtual-dev-state:5] Set("PJSIP/3000019-000001a0", "ODBC_ID=636") in new stack
-- Executing [s@sub-udpate-virtual-dev-state:10] Set("PJSIP/3000019-000001a0", "DEVICE_STATE(Custom:VirtualDev33)=NOT_INUSE") in new stack
-- Executing [h@sub-local-dialing:3] GosubIf("PJSIP/3000019-000001a0", "0?dynamic-routing-connected,s,1(ANSWER,3000019)") in new stack
-- Executing [h@sub-local-dialing:4] GotoIf("PJSIP/3000019-000001a0", "0?call_ended") in new stack
-- Executing [h@sub-local-dialing:5] GosubIf("PJSIP/3000019-000001a0", "0?wake-up-no-answered,s,1") in new stack
-- Executing [h@sub-local-dialing:6] Gosub("PJSIP/3000019-000001a0", "sub-call-completion-check,s,1") in new stack
-- Executing [s@sub-call-completion-check:1] NoOp("PJSIP/3000019-000001a0", "FEATURE: CALL COMPLETION CHECK") in new stack
-- Executing [s@sub-call-completion-check:2] Set("PJSIP/3000019-000001a0", "CC_MODE=none") in new stack
-- Executing [s@sub-call-completion-check:3] Set("PJSIP/3000019-000001a0", "CC_MODE=none") in new stack
-- Executing [s@sub-call-completion-check:4] Set("PJSIP/3000019-000001a0", "CC_MODE=none") in new stack
-- Executing [s@sub-call-completion-check:5] GotoIf("PJSIP/3000019-000001a0", "1?end") in new stack
-- Goto (sub-call-completion-check,s,17)
-- Executing [s@sub-call-completion-check:17] Return("PJSIP/3000019-000001a0", "") in new stack
-- Executing [h@sub-local-dialing:7] NoOp("PJSIP/3000019-000001a0", "Call ended") in new stack
-- Executing [h@sub-local-dialing:8] Gosub("PJSIP/3000019-000001a0", "notify-call-hangup,s,1") in new stack
-- Executing [s@notify-call-hangup:1] Verbose("PJSIP/3000019-000001a0", "0, Extension Hangup") in new stack
Extension Hangup
-- Executing [s@notify-call-hangup:2] GotoIf("PJSIP/3000019-000001a0", "1?:incoming") in new stack
-- Executing [s@notify-call-hangup:3] UserEvent("PJSIP/3000019-000001a0", ""EXTENSIONS_SUMMARY","Data: EXT_TO_EXT,PJSIP/3000019-0000001v,PJSIP/333_1-000001a1,LOCAL"") in new stack
-- Executing [s@notify-call-hangup:4] Goto("PJSIP/3000019-000001a0", "end") in new stack
-- Goto (notify-call-hangup,s,7)
-- Executing [s@notify-call-hangup:7] Return("PJSIP/3000019-000001a0", "") in new stack
-- Executing [h@sub-local-dialing:9] Hangup("PJSIP/3000019-000001a0", "") in new stack
== Spawn extension (sub-local-dialing, h, 9) exited non-zero on 'PJSIP/3000019-000001a0'
