Changing default ports
Greetings all,
If I change:
  • Default Technology PJSIP bind and TLS Bind to something else than default 5060 and 5061
  • Default Technology SIP bind and TLS Bind to something else than 5062 and 5063
And then if I update the Firewall / Service ports to match those changes,
Will Vital PBX automatically update the phone configuration files?
Or do I need to run a bash script to scan through all the ports and update all files?
Or is there an option any where to force an update then push it to the phones ?
Anyone on this one ?
I saw that when I edit a conf file, it is being overwritten back by VitalPBX …
Do I need to delete all extensions and re-create them ?
