mo10
September 30, 2021, 9:21pm
1
There is a bug on Provisioning (Scan Network).
I sure created a template for Fanvil X6U before. But when i try to select it it says “No results found”.
If i add the device manually: no problem
Could you please check? Should be a bug on all Brands.
miguel
September 30, 2021, 10:52pm
2
Thanks for reporting it. We will check it.
mo10
December 1, 2021, 10:46pm
3
Hi @miguel and @admin
this is still an issue on 3.1.4-1.
Scan-Network is useless like this. Thx
PitzKey
December 30, 2021, 8:42am
4
Hi @mo10 ,
It looks like this is fixed in the latest version. Can you please confirm?
mo10
December 31, 2021, 2:14pm
5
Yes, it’s working now. Thanks!
Would be nice to be able to set the “Description ” right away.
Like this:
mo10
May 17, 2022, 2:03pm
6
This is NOT working.
After hitting save it will go to the provisioning but the new phone will not be in the list.
