Trying to run a manual backup and getting the following
The backup is shown afterwards after a page reload, but not sure if it was indeed completed properly and really the message is certainly odd
Vitalpbx: 3.2.4-1
Vitalpbx: 3.2.4-1
Try the following:
Optimize the MariaDB configurations using the command below. Keep in mind that this command will restart the MariaDB service, so do it when the system is not in use.
vitalpbx --optimize-mariadb
Try to run the backup from the GUI. If the backup is still failing with the message above, then try creating a backup without the CDR.
