With the update to Vital 3.1.0.1, *4 for parking is not working on calls. Seems like the DTMF code is not being sent by extensions for some reason.
Is there anything that changed related to this?
*2 doesnt seem to be working either not detected at all either during the call.
The blind transfer process is starting when dialing #, not actually waiting for #1, to be dialed for some reason, so most likely therer is something odd with the feature codes?
Hello @hlev
Try to comment out the custom_atxfer => and custom_blindxfer => custom features in /etc/asterisk/vitalpbx/features__10-application-map.conf
nano /etc/asterisk/vitalpbx/features__10-application-map.conf
then reload the features module
asterisk -x"module reload features"
This should fix the issue.
Vital fixed this in version 3.1.1-1
