Vitalpbx mobile android
Any updates on this and/or an ‘official’ release date?
It is now available in the Google Play store VitalPBX Mobile.
Hi Sir,
I get warning on console asterisk when call is hold
       > 0x7fdcf04f23c0 -- Strict RTP learning after remote address set to: 10.134.115.195:4000
    -- Started music on hold, class 'default', on channel 'Local/104@queue-call-to-agents-00000025;1'
[2021-11-05 05:26:56] WARNING[20699][C-00000023]: codec.c:394 ast_codec_samples_count: Codec opus returned invalid number of samples.
Flow Test
Vitalpbx Mobile (Ext : 900) → call to queue → Talking to (Ext : 104) → Then Ext 900 Pres Hold
Does this affect you in some way?
Hi @miguel ,
No Sir, Not effected. The warning message show if hold from vitalpbx mobile.
Ok, nothing to worry about then.
Hi @miguel
Please confirm, why sometimes “SIP Registering” / “Error” occurs on vitalpbx mobile?
I’ve tried to disable/enable the account but still “Registering…” / “Error” appears. After a while, I tried to close V.Mobile and re-open it then it can be registered.
Is my network normal? Yes, because I installed 2 softphones for comparison.
Hi Sir @miguel
Please try this scenario
Vitxi (ext : 104) call to V. Mobile (ext : 900)
When it rings in ext 900 then rejects. Minimize V.Mobile, then click the V.Mobile shortcut again. Registration will appear…/error…
That’s what happened to me, please help to try it too, if experiencing the same thing.
I don’t understand. You have two registrations, same credentials from the same phone?
Hello, we release the last estable version in Google Play Store, try it, this version have a lot of bugs corrections and better server registration, and if you have any recommendations please let us know.
No, different extension and different softphone.
The mobile application horrible…
when i press digits it disappears …
like i want to dial 101 … the moment i press 10…i remove the dialed number
if anyone experiencing this ?
