Update libsrtp to 1.5.4 or later
I’ve some SRTP issues, and the Asterisk wiki…
https://wiki.asterisk.org/wiki/display/AST/libsrtp
…says ‘the minimum supported version of libsrtp supported by Asterisk is 1.5.4’.
Unfortunately, CentOS 7 only includes libsrtp up to 1.4.4.
So can you tell me how to securely update to libsrtp 1.5.4 or later?
I would prefer a followable step-by-step guide.
BR
Me again…
I see masses of messages like this…
WARNING[5417][C-0000002a]: chan_sip.c:10937 process_sdp: Failed to receive SDP offer/answer with required SRTP crypto attributes for audio
  == SRTP unprotect failed on SSRC 218124252 because of authentication failure 10
  == SRTCP unprotect failed on SSRC 218124252 because of authentication failure
  == SRTP unprotect failed on SSRC 218124252 because of authentication failure 160
Same issue as described here…
But should also be solved by this, as already described above…
So please can anybody help how to install libsrtp 1.5.4 or later on Vital?
BR
@pbxprovider,
We expect to migrate to Debian in a couple of months maybe Debian comes with the latest version of the libsrtp library.
Our asterisk packages come compiled with the flag “–with-pjproject-bundled”, I don’t really know if activating this flag makes Asterisk download the right version of the libsrtp library, but the Asterisk documentation says the following:
For production builds and use ./configure --with-pjproject-bundled (of course) to make sure both Asterisk and pjproject are in sync with respect to library versions.
