SMTP sending issues with vitxi
Gentlemen,
I have issue making SMTP from vixit working.
We get the following error message
The mail could not be sent
Connection could not be established with host XXXXXX.XXXX :stream_socket_client(): SSL operation failed with code 1. OpenSSL Error messages: error:14090086:SSL routines:ssl3_get_server_certificate:certificate verify failed
Which makes no sense to me, as the cert I fully valid
Where and when do you get this error?
Hello Sir,
Try changing the media encryption from TLS to SSL and set the port to 465.
Good afternoon,
I have tried both TLS and SSL
Changed port etc
Tried on 3 different smtps
Same results
Do you have a self-signed certificate? or do you have a valid one?
We have a valid one,
Correct me if I am wrong. It looks like the mail server’s cert is not valid.
Does the same configuration work within the PBX’s mail settings?
same settings works perfect with the PBX,
I am also seeing this issue on Vitxi Version 1.0.6-6
The same smtp settings on the Vitalpbx gui work without an issue
Hello Sir,
Can you share a screenshot of your email settings on VitalPBX?
Best Regards!
