SMS/MMS in VitXiWebRTC and Mobile apps
There is actually a way to get the extension number based on DID but it’s a really long database query, see below.
mysql -u root -D ombutel -s -N -e "select ext.extension from ombu_extensions ext left join ombu_destinations dest on (dest.index = ext.extension_id) left join ombu_inbound_routes ir on (ir.destination_id = dest.id) left join ombu_destinations_category destcrid on (destcrid.id = dest.category_id) left join ombu_modules module on (destcrid.module_id = module.module_id ) where ir.did = '${var_containing_did}' and module.name = 'extensions';"
I have not tested this from within a dialplan, so I’m not sure if you’ll be able to use root or you’ll have to create a new user and password with access to the ombutel database.
I’m sure there is a solution. May need to be patient.
user vitalpbx and password vitalpbx might work.
Default. No need to create.
Still wishing for supported SMS/MMS
Wondering when SMS support will be released? This is a key requirement for us as well. Will V4 include SMS support?
We are currently working on it. At the moment, it is not available for VitalPBX 3 or VitalPBX 4.
Best Regards and Happy New Year!
Is there any timeline for this? I think this is a very requested feature and I think this would make VitalPBX even more attractive.
Do you have any information about when the MMS feature will be available or if it is planned for the future?
We are currently developing SMS and WhatsApp integration in VitXi.
Please stay tuned to our communication channels for updates.
