I just installed the Phones Provisioning add-on, but i was not aware it was a licensed add-on.
Now i want to remove it, but i just have the buttons buy a license and the blue information button.
How can i remove this add-on?
System is installed just 2 days ago, vitalpbx 3.1.0-1 and these are my first steps into this pbx, i’m very pleased with how everything works.
I discovered uninstalling / removing the add-on is possible through the cli, using yum remove.
So there is a workaround.
There seems to be two packages:
provisioning-core
and vitalpbx-phones-provisioning
, I am not sure if removing both will break something.
I only removed vitalpbx-phones-provisioning, this removed the menu items for the gui, which is good enough for me.
The Add-On page now also states phones provisioning is not installed.
I believe that even tho Provisioning is a paid add-on, it still allows you to provision a limited amount of devices without a license.
mo10
August 9, 2021, 8:21am
6
True, which is 20 free devices afaik.
mo10
April 16, 2022, 10:13pm
7
And 50 free if you have at least one commercial addon licensed or the VitalPBX Starter License.
